Question about Indesit W 123 Front Load Washer
I have a indesit WIL163s. when it is plugged in all the lights ont display come on except for the 2,4 and 6hour ones then after a minute goes off. After the lights have gone off the machine doesn't function at all
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 31, 2008
What wires go where
I would suggest getting a service manual to see where the wires go. you can go to: http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf, the manual is posted there. It should have the number of customer service as well.
May 06, 2014 | Indesit IS70C Electric Dryer
Indesit idc75
sounds like its a drum glide worn out
Jan 04, 2014 | Dryers
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
I have an indesit WIL163S that just pumps and nothing else, can't stop it or change program.
If it will not reset, and just keeps pumping water, then it is likely to be a control module fault, or possibly a selector switch problem.
You may have to call en engineer to it.
Jan 20, 2010 | Washing Machines
Indesit Evolution 1600 WE 16 Washing Machine with F 05 Display
Get unit to spin and drain. See if any of those are a problem. Check if heating element has a circuit and if possibly an over temp cut out has occured. Normally if a code no. has come up, a certain condition has occured which should be rectified.
Sep 16, 2009 | Washing Machines
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
LG LFX25960SW Refrigerator--Display goes bizerk
It is going thru a diagnostic process, But this is only to happen when you either open the circuit board and press the test button, or use the front display keypads. I would have the circuit board checked
Jul 27, 2009 | LG LFX25960ST Stainless Steel French Door...
Indesit
Click above (ie. below the Fixya symobol, on yr model No. You will come to Troubleshooting & Support. There is a posting by "again". First 5 postings?
May 07, 2007 | Indesit WA 115 Front Load Washer
Indesit W 123 Front Load Washer Logo
447 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
