Question about Canon DR-7580
Hi, When starting the scanner, the feeder goes up but then just stays there and doesnt come down.. Can you help what might be wrong?? Thanks
  • 490 Answers
There is a sensor under the paper tray and when powered On, the tray goes to home position (HP). If the sensor has failed or slightly dislodged, you get this problem. Normally these sensors don't fail.
S. Mohan, Chennai, India
Posted on Oct 17, 2010
How do i get the feeder to stay up in the feed position. After it comes up it beeps and goes back down to the load position
The motor control board handle few sensor within the feeder. Check the cable telephone for proper connection. And at the very top of the feeder there is a sensor and one on the feeder itself at the bottom. If those sensor are good the problem could be the motor control board.
Jun 20, 2014 | Xante Ilumina Digital Color Press Printer
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Apr 01, 2011 | Welding Tools
Black row are comeing for scanning
its one of 2 possibilities
If you are getting black lines down the page, then you have a bad scanner assembly. It will be too costly to replace.
if you happen to be using a document feeder which i dont believe so, you might have some dirt in the scanner glass that needs cleaning.
thanks adi
Apr 21, 2010 | HP ScanJet 2400 Flatbed Scanner
When sending a fax, do i face the front side of my document face down or the back side down?
If you are faxing using the feeder , the front page will face up. and if it is on glass/scanner will be faced down.
Thanks for joining us, for more assistance please stay connected with Fixya.
Have a nice day.
Mar 08, 2010 | HP LaserJet 3330 All-In-One Printer
Lines on Outgoing Faxes and Copies from Feeder Is there a way to clean the doc feeder scanner? I have a big line going down the center of the page when I copy or fax from there. Thanks!
If you lift the top of the unit so that you can see the scanner glass and clean the surface on the left side and the very end of the scanner you should be ok. The sheet feeder runs the pages through the feeder and down to the glass at the end then back to the feeder and out to the stack of pages. If you try to scan anything with wet ink, highlighter, marker, etc some may come off on the glass and cause the lines to appear. Just use windows on a paper towel, not sprayed on the unit.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Lines on my copies
As the page you wish to copy goes through the document feeder, it passes the scanner as well as a white plastic band that the scanner "compares" the dark writing or data on the page to. If this white plastic band is not very clean, the scanner reads the dirt as if it is part of the image you are scanning. Try cleaning the band as thoroughly as possible, as well as the small piece of glass to the left of the larger glass on the flat bed scanner. Make another copy to test your results.
Hope this helps!
May 07, 2009 | HP LaserJet M5025 MFP All-In-One Printer
The sheet feeder of the canon IP880 doesn't work properly
Hi all of you,
Clean carefully the ruber feed roler. use brush, water and detergent .
thanks
Hamedo
Nov 17, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
White line down side of page when scanning
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanning does not stops
please check all sensor arms in the document feeder. The sensor arm in the middle just below the separation pad is called 'paper end sensor'. If this sensor arm is blocked or broken the scanner don't stop the feeder.
Another possibility is a driver error.
Jan 08, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
78 people viewed this question
old marine
old marine
