Question about Lexmark C530dn Laser Printer
I have an error message 120.10 service fuser error, what does this mean?
  • 2,296 Answers
Service Fuser Error appears when the fuser does not warm to the required temperature to operate properly. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 05, 2011
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
Mar 02, 2015 | HP LaserJet 5200dtn Printer
I have a Lexmark C534n color printer error message comes up 120.10 service fuser error. What does this mean.?
It means there's an issue with the fuser, and the fuser likely needs service or replacement. I would not recommend doing this yourself if you haven't done this before, take it to a repair shop.
Feb 24, 2011 | Lexmark C534N Printer
I have an error message that says 924 service Fuser Error What does that mean?
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser yourself which costs around $350, so I think you would be better off getting a new printer unless you find a second hand fuser on Ebay.
Sep 03, 2010 | Lexmark T632 Laser Printer
''Call Service :03'' message on Muratec F-560
IF MACHINE IS SAYING "PLEASE CALL SERVICE" 03 then it is indicating you have a fuser problem.(thats the part that warms up to melt the powder onto the paper.) Until the problem with the fuser is repaired this error code will not go away.
Jun 10, 2010 | Muratec Office Equipment & Supplies
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
Press "STOP" TO EXIT.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
We have a Canon IR400S with the following error message - Switch main power on & off, E005. Switching power on & off did not clear error. Can you tell me what the error message means?
The error message means that the Fuser web has a problem. This is the part that cleans the upper fuser roller on the copier. It's located inside the left door of the copier and more than likely requires a copier technician to replace it. Fuser webs(belts) gradually get consumed after about 100,000 prints. The other possibility is that you may have had a brown-out or some other kind of power fluctuation in your area and the error just needs to be reset in service mode, but I'd check the first solution 1st, the part is cheap $25-$50.
Dec 10, 2009 | Canon Office Equipment & Supplies
Fuser error on my ibm infoprint color 1464
The error is Fuser cam position not found. Have you tried reseating the fuser? Does the fuser make any loud sounds? Based on the error message, it could either be the fuser, or the system board.
Apr 08, 2009 | IBM Infoprint 1116 Laser Printer
123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
Mar 19, 2009 | Lexmark C762 Laser Printer
I have a Lexmark X422 It has a error message when I try to print anything. It says 922 service fuser error
This means Fuser failed to reach
standby temperature.
The only answer is to replace the fuser, part number 56P0648 110 VOLTS, 56P0671 220 VOLTS.
Please advise if you require instructions
Aug 04, 2008 | Lexmark Office Equipment & Supplies
Lexmark C530dn Laser Printer Logo
265 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
