Question about Zanussi Washing Machines
Zanussi time line 1600 jet system 6kg washing machine warning error code E34
  • 74 Answers
SOURCE: Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Posted on Feb 17, 2008
SOURCE: ZANUSSI WASHING MACHINE
seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
Posted on Dec 29, 2007
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
SOURCE: washing machine zanussi jet wash
unplug machine turn water off then take water pipe off machine,take machine outside and lay on its back,there is two moters up in the top right off machine looking in the bottom of machine, undo the three pipes and two/three srews take both pumps out undo three screws on the top pump split it and unblock then pup it all back.remember to right down wot you have done to pup it back right,it took me approx half hour to fix mine
Posted on Feb 28, 2009
barkencoa
  • 3463 Answers
SOURCE: my zanussi timeline 1600 washing machine has
I suggest that you check and clean the filter.
This should be located at the bottom front right of washer behind drop down cover or flap. Unscrew anti-clockwise to remove and clean
Please rate my solution.
Thankyou.
Posted on Jan 16, 2010
Zanussi jet system washer error code 247.whats this mean?
Nothing. It is not error code, maybe is time washing for example: 2 hours and 47 minutes. All errors code starts with letter "E" and two numbers or only with two numbers.
Dado
Dec 12, 2016 | Zanussi Washing Machines
The washing machine has stopped midcycle and the start button is flashing red do you have any ideas of what may be causing this?
try to cancel it out and start again, if it won't cancel machine is telling you that something like belt broken or door open, etc.
Sep 22, 2015 | Zanussi Washing Machine Door Seal...
I have a zanussi jet system 1600 and it's not allowing us to do a wash,we start the wash and it shows as 1.40 mins till complete then it jumps to 3 mins and stops,it's leaving all are clothes soaking and...
i guess its machine pcb error. take out front pcb and dry it well and reconnect to washing machine. still its not working you have to replace 8000 mhz xtal in control pcb.
Jun 05, 2014 | Washing Machines
Zanussi jet stream 1600 door locked
SOUNDS LIKE THE LATCH IS NOT WORKING AS IT SHOUD. I WOULD START BY REPLACING IT FIRST.
May 23, 2014 | Zanussi IZ161S Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
No hot water in my washing machine
heater thermostat need replacing at worse you may need a new pcb .call an expert
Feb 11, 2010 | Washing Machines
Just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Apr 09, 2008 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
