Question about Canon FAX-L800 Plain Paper Laser
Change incoming fax number - Canon FAX-L800 Plain Paper Laser
    President:
  • 2,992 Answers
Unless I'm misunderstanding your question, your fax machine has nothing to do with the incoming fax number. That's assigned by your phone service provider to the telephone line the fax machine is connected to. The only way to change that number would be connect the machine to a different phone line. This might be as simple as just plugging the phone cord into another jack if that line already appears at a convenient location, or it might mean a visit from a technician to place a jack where it's needed. Or you can contact your phone service provider about assigning a new number.
I hope this has helped. If not, please post a comment with more information about your question and I'll try to help further.
Posted on Oct 11, 2010
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
I want to send all incoming faxes to an email address instead of printing them
You can contact to the toll free number of the manufacturer...Engineer will change the setup of incoming messages..........
May 15, 2009 | Office Equipment & Supplies
Ricoh Aficio 350 change number of rings before fax answer and/or auto detect incoming fax.
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
Mar 25, 2009 | Ricoh Aficio 350e Printer
Setup fax machine with new telephone number
no change is needed for incoming faxes (it your new number) and the person (s) on the outgoing side will see the new number also....so just connect it correctly and happy faxing
Mar 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Canon FAX-L800 Plain Paper Laser Logo
56 people viewed this question
old marine
old marine
