Hello I have a 26'' LD2661HDFVT and the remote was working fine. It stopped working and I have changed the baterries twice but it still will not work. Any ideas?
  • 998 Answers
Check the battery terminal the one that connects the pcb it might be loosed
Posted on Oct 11, 2010
I changed the baterry but when i try to start the horns start hawnking
you have activated the anti theft system.you need to have the remote to lock and unlock the car.
the other thing to try is lock and unlock the passenger door twice with the key
Feb 23, 2015 | 1996 Nissan Maxima
How do i reset my universal remote... i took the baterry so my daughter couldnt change the channel and when i put it back in, it stopped working...lol
try holding the power button down for about 5 seconds ortill the light on the remote flashes three times it should have and auto program try that
Aug 06, 2011 | RCA Universal Remote Control
I cant find the code to program my wide open west remote control to turn my Vizio TV on and off
SEARCHING FOR YOUR CODE
1. Turn on your TV.
2. On the remote control, press TV once; it will
blink once.Then press and hold SETUP until
the TV key blinks twice, then release SETUP.
3. Enter 9 - 9 - 1.The TV key will blink twice.
4. Aim the remote control at the TV and slowly
alternate between pressing PWR and TV.
Stop when the TV turns off.
5. Press SETUP once to lock in the code.The TV
6. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or CBL)
for the device you are searching for.
http://www1.wowway.com/remotecontrol/
Good luck, pls rate it :)
Dec 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Lock remote stopped working. changed baterry, tried to reprogram as per manual nothing works
some auto parts stores have a display at the counter where they sell new remotes or fob's. The display has a sensor that lights up when you use your remote. Point the remote at the display and press any button if the light comes on your fob is likely ok. may need to check the receiver. good luck
Nov 30, 2009 | 2002 Ford Explorer
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
Stopped working. replaced batteries and still
well 1st of all try to check if there is any corrosion on ur remote terminals if there is not try to check the voltage of each baterry also check if there is any corrosion but if not try to install the baterries back again and bring any mobile phone then try to see the video of the outout signal from the remote when u press and hold on any button on the remote at the same time u must direct the remote closely to the mobile phne camera so if u see the light of the IR LED then the remote works but the problem is from ur IR receiver on the device but if the IR LED is not blinking then u must dissassemble the remote and change the IR LED with new one or u must change the ceramic crystal
Jun 29, 2009 | Bose Televison & Video
When I adjust the volume on the remote control it changes the channel, but not on every occasion.
Hey,
This could be due to the accumulation of dust inside the remote control. You can try to open up the controller and just clean it up.
Thanks
Apr 15, 2009 | Televison & Video
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
Remote Control Control Codes
has anyone solved this problem???
Jan 13, 2008 | Audio Players & Recorders
Quasar VV-2009
Here is the link to the manual if you need it; http://service.us.panasonic.com/OPERMANPDF/VV1309.PDF check page 26 item 4 - vcr lock - just a possibility this may solve the problem, long shot. Let us know which remote you have and we may be able to find out how to program it for your tv. page 37 gives you contact details if you want to buy the correct remote. I suspect that with the correct programming, your universal should work fine though. Hope this helps :)
Mar 16, 2007 | Quasar TP-2009D 20" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
