Question about HP LaserJet 9500n Printer
Hp color laserjet 9500 error message "Close upper or Right door" when you close nothing happens.Please help.
    Master:
    Sergeant:
  • 381 Answers
Most likely a faulty sensor
Posted on Oct 11, 2010
HARD RESET hp laserjet m175nw ?
Try this:
1- Make sure printer is off.
2- Press and hold Red X and Right Arrow key.
3- Switch printer on (Red X and Right Arrow still pressed down)
The goal is to get the printer display a "Printer Settings Init" message. Release the two buttons when you get this message. If nothing happens, try the procedure over again.
May 14, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
Close upper right door
I would try closing the door, then power off and unplug the printer for at least a minute. This may clear out the error.
If still no go, open the door and make sure there is nothing blocking the door from closing completely and also locate the door sensor and inspect for damage to the sensor as well as the part of the door that disables the senor / interacts with the sensor when the door is closed.
Nov 09, 2011 | HP LaserJet M5035 MFP Printer
I get an error message that there is a paper jam in the front door, there is no jam. I open and close the front door and then it says the jame is in the fuser, ive taken that out and no jam hp 3550 laser...
Often when you get this error, there is a jam that is very difficult to see. You need to open the printer, remove the bottom two cartridges and the transfer belt. Then close the door part way and look straight down inside the printer. That part of the printer is called the registraion assembly and there is a paper sensor in there that often gets stuck with a small piece of paper after a paper jam is removed. You can carefully lift up on that assembly to unseat it and have a look underneath..
May 03, 2011 | HP Color Laserjet 3550 Printer
I have an HP Color Laserjet 3600n with error 10.10.03
Thank you for contacting FixYa with your printer issue.
www.hp.com Support Document (110993)
10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
  1. Open and close the front door.
  2. Remove the print cartridges, and then reinstall them.
  3. Close the front door.
  4. Turn the printer off and then on.
  5. If the error persists, contact HP Support.
Helpful CLJ 3600 Error Message Tables:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478&prodTypeId=18972&prodSeriesId=501044
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 22, 2011 | HP LaserJet 3600n Printer
I have a HP color laserjet 1600 printer, I'm having a problem with this kind of error message a "door open" message error...there's no paper jam, no paper stucked in paper path...it's just an error message...
well that switch is to detect if the door is open or closed so maybe it is bad when you think it is not. well try unplugging the printer and remove the driver and then reinstall the driver plug the printer back to get it re recognized in the system and then set the settings.
Jul 29, 2010 | Office Equipment & Supplies
10.10.00 Supply Memory Error?? Unable to read cartridge data. Open and close front door to reestablish the contacts.
This is a chip error. This happens frequently when using generic brand cartridges & not OEM genuine. You will need to replace the toner cartridge
Jul 19, 2010 | HP Color LaserJet 3500 Printer
Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Jun 07, 2010 | HP LaserJet 2840 Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Door error message
    you may have a broken cartridge lock or door sensor. remove all the toner cartridges. then open and close the door and watch for 4 white hooks that open and close on the right interior of the machine where the cartridges are installed. if three of the 4 open and close with door then the one that doesn't is your broken lock. if all 4 work then you have a broken door sensor. Good luck.
    Aug 10, 2008 | HP Color LaserJet 2600n Printer
    HP LaserJet 9500n Printer Logo
    223 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
