Question about RCA D52W19 52" Rear Projection Television
Part replacement how tough is it to replace this part and can I do it? Do i need a proffesional installer?
    Genius:
  • 1,030 Answers
Which part are you looking at to replace
Posted on Jun 06, 2008
How to remove and replace radiator
To remove and replace a radiator is a major mechanical job, requires some quite complete equipment and some mechancal knowledge.
Last time I had my radiator replaced, it took about 2 hours for a proffesional radiator mechanic . Are you sure your really want to do it yourself?
Better then any "explanation", watch these youtube videos:
How to change 2000 2003 Malibu Radiator Part 1 Removal
Radiator Cooling fan assembly repair install Chevy Impala
How to Replace Radiator How to Remove Your Radiator
How To Install Replace Engine Radiator Cooling Fan 2006 12 Chevy Impala
Sep 09, 2015 | 2003 Chevrolet Impala
Trips breaker
To be short, the only thing in the machine that really has the capability of causing that is the compressor. Its got a floating short in and when it makes contact it trips the outlet/breaker. Check for any exposed wires just to be sure but I'm pretty certain that the compressor is the culprit and either it or the machine needs to be replaced or a proffesional sercvice tech called.
May 14, 2012 | Refrigerators
How to replace aircon condensor on 2002 chrysler voyager
firstly you will need a proffesional to drain the gass off the cooling system and it might be cheaper to pay them a few dollaors extra and they will install it for you-leak free and regassed.
Nov 15, 2011 | 1995 Mercury Villager
I have Presario V3611AU Notebook PC and it's keyboard ls not working, i've tried to install many drivers and i've change the windows also but it is not working. pls i need help.... RAVI....
Keyboards on laptop actually dont need drivers. If not a single key is working, your keyboard will have to be replaced.
I would suggest letting it be checked by a proffesional.
Jun 20, 2011 | Computers & Internet
Please help my Olympus Stylus Tough 6020 seems to be stuck in playback mode. I can review the photos no problem but when I press the button to change the mode to take aphoto the screen reverts back to...
Unfortunatly the Olympus 6020 does not hav a dedicated hardreset switch, nor a key sequence to initiate reset. So if you cant get into the camera menu, and reset the camera from there. Or if that does not work. The camera has to be serviced by proffesionals.
Mar 08, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
Need to remove and replace starter on 1996 Dodge Caravan
quite simple and yet tough your first time
1.) install a memory saver
2.) disconnect the battery cables
3.) disconnect the wires at the starter
4.) unbolt the starter
5.) reverse to install
May 16, 2010 | 1996 Dodge Caravan
I got a Hyundai accent 95, my car mechanic says its very tough to add any air cooler in my car, If i do so, i'll have to change the compressor and it will charge me a lot. Please advise, is it really so...
most probably due to age of system/car ? and possible corrosion deteriation of pipe work etc ? to recharge/pressurise system correctly would/may be a risk ? and involve cost rising if any leaks arise/loss of coolant gas via pipes /pump etc i would consider these possibilities b4 you pay $$$$$$$s ??? this job is a proffesionals job as regards refill/pressurising not diy so heed the advice of your mechanic he probably knows best for your car and pocket ??
Dec 27, 2009 | Hyundai Motor 1995 Accent
Rinnai model 531 2520FFU 91 N
Have the installer replace the inducer blower assembly. Rinnai will cover the repair and your technician will get paid from Rinnai.
Mar 03, 2008 | Heating & Cooling
Vist Home & Proffessional
partition your hard drive thats how you can run 2 operating systems on your computer im running xp pro and vista ultimate
i recomend you use vista ultimate it has it all
Jan 03, 2008 | Microsoft Windows 98 for PC
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
