Question about Vtech Kidizoom Digital Camera
Our daughters vtech Kidizoom Camera (model number N448) will turn on but none of the buttons work. After a while it just switches itself off. Have tried changing batteries and using reset button. Does anyone have any other suggestions????
SOURCE: y is it not working
The camera "thinks" it's connected to a TV. We had the same problem. My wife used a bobby pin to "trick" the camera into thinking it was being disconnected from the TV by probing the pin into and out of the TV connector on the side.
Posted on Feb 24, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Vtech Kidizoom camera. Have changed batteries but
Try cleaning the battery contacts inside the battery compartment. Do this with a cotton swab "dampened" in rubbing alcohol. You may also want to clean the battery contacts and the charging station if so equipt. Thanks, Dana
Posted on Jan 06, 2010
SOURCE: Vtech kidizoom camera will just freeze while you
hi i got a kidizoom for my daughter. i am trying to upload music from itunes it seems to go on but when i switch on the camera i can't find it anywhere. what am i doing wrong?
Posted on Jan 12, 2010
SOURCE: Vtech kidizoom camera does cannot find SD card
I had similar problem. In windows i formatted the SD card as 'FAT' rather then 'FAT32' (right click on card and select format) and that made the camera recognise it!
Posted on Jan 14, 2010
  • 5 Answers
SOURCE: changed battery won't turn on
Try inserting a tooth pick into the reset hole found just below on-off button and slightly to the left. Apparently the camera requires a reset after batteries have been changed. Our problem after resolving this problem is now the camera doesn't always stay on, i.e., turns off by itself.
Posted on Jul 23, 2010
I have changed the batteries on my vtech kidizoom camera pressed reset button it turns on fter a while but freezes
suggestions. Different type of battery? Two different brands of battery? check the internal contacts to see that they do not have corrosion from the old ones/
Nov 09, 2013 | Vtech Kidizoom Digital Camera
Changed battery won't turn on
Jul 19, 2010 | Vtech Kidizoom Digital Camera
My daughter's Kidizoom won't turn on - I have replaced the batteries and it makes no difference - I have checked the batteries in another console and they are fine. Any ideas?
I initially thought my batteries were dead, too. Try inserting a tooth pick into the reset hole. It can be found below the on-off button and slightly to the left. Apparently after battery changes, the unit needs to be reset. This worked for me.
Jul 11, 2010 | Vtech Kidizoom Digital Camera
Vtech kidizoom camera will just freeze while you are operating. Somewhere I read, if you hit the reset button, it will then work. This is true, but the camera freezes multiple times an hour. I then have to...
Dec 31, 2009 | Vtech Kidizoom Digital Camera
When i insert an sd card the vtech kidizoom camera wont turn on at all.
I am not a tech wiz but have just managed to put the card in my daughters camera! Normal SD card tight fit,it looks like it needs to go all the way in but doesnt. Either you have it in wrong or wrong card? Metal bits down! When I turned it on you then have to go to the tools sign to switch to memory card .Hope this helps.
Jul 25, 2009 | Vtech Kidizoom Digital Camera
Feb 20, 2009 | Vtech Kidizoom Digital Camera
Loss of Photos
Remember, if you're in the photo album if you accidentally hit the delete button with a picture on the LCD screen...it's outta there.
Feb 01, 2009 | Vtech Kidizoom Digital Camera
Y is it not working
Sep 01, 2008 | Vtech Kidizoom Digital Camera
Vtech Kidizoom Digital Camera Logo
Top Vtech Cameras Experts
Tony
Are you a Vtech Camera Expert? Answer questions, earn points and help others
