Question about Philips MZ-7 CD Shelf System
Hello, My philips mz 7/22 doesnt work anymore. I bought a new passive subwoofer and I have one old reciver. I connected old reciver with subwoofer and philips subwoofer output with old reciver. I turned both recivers (old reciver and philips) on and after that, philips didnt took any power in. What can be a problem and what is the solution?
SOURCE: philips plasma won't turn on first time
I have found this on a site and am in the proccess of trying to mend my plasma PF9964 as it started to take longer and longer until it stopped coming on. I've got the back off so I just need to un solder capacitors and replace. Here's the info I found. Bad power switch circuit General Comments If you have this problem with your Philips 32PF9964: When I switch the TV on, it appears as though it is going to start i.e the green light comes on, then after about 10 seconds it switches itself off and the standby light flashes red. It takes 10 /12 times before it starts and is getting worse. This is the solution: The problem is three caps. Change the cap 2663, 2664 both 100µ/25V and 2662,1000µ/25V. After you have changed them your TV will work again. You will find them easy if you unscrew the back on the plasma TV. Cheers, Mike
Posted on May 18, 2007
  • 521 Answers
SOURCE: Subwoofer no longer works on
re check whether the pins are plugged in a proper place.
Posted on Aug 17, 2008
easyq
  • 144 Answers
SOURCE: Philips Home Theatre System - no sound or power light on sub woof
reset the device to factory settings, it is written in your manual how to do this. If that doesnot work, unplug the powersocket for about 30minutes, it will cause an internal reset which might solve it.
Edgar
Posted on Jan 29, 2009
  • 1039 Answers
SOURCE: we also have a 42 inch phillips plasma tv, its
If you had a power surge check your homeowners insurance.
Posted on Apr 25, 2009
Moe66
  • 13 Answers
SOURCE: I need pinout assignments for a Philips 5.1 Home
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Posted on Feb 04, 2011
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
We understand that your problem is: Hello, I bought a LG 42sl80yd tv from china, but now i am in Bangladesh, when i tune tv programm it tune ok, antina and cable connectivity, but its sound is not ok, as...
PAL B use 5.5 Mz and 6.5 Mz in DK and I so you need modfy the sound if section removing 6.5 Mz ceramic filters with 5.5 Mz fiter and so on better way buy old VCR and connect video out and audio out to your LCD and put AV to view the TV channels
Aug 26, 2010 | Televison & Video
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Old receiver, new subwoofer- how to connect?
NOOOOOOOOOOOOOOOOOOOOOOO! Never connect speaker outputs to anything that looks different, like RCA connections. Can you say crispy critter?
Your receiver sounds like it won't send specific Subwoofer of Low Frequency Effects information to the Sub so we're cheating by adding a sub. If you named the model of each we may have a better shot at naming the output you need to use.
I'm curious. How did you have the old passive sub working?
Basically what you may have to do is feed (probable) full range audio to the Sub using an RCA splitter to combine the L and R outputs found, oh, at any Tape Output that you're not using. The Sub will only reproduce what it can. The presence of higher frequencies won't bother it. If it has its own volume control you'll be able to balance its volume with the rest of your speakers.
Mar 18, 2010 | Audio Players & Recorders
HTS9800 Wireless receiver not working
I have just bought one of these today and have had the exact same problem. No rear sound and no blue light on the receiver box.
Solution:
What philips don't tell you in the manual and on the support site is that the receiver box has a switch hidden under a white sticker; next to the left of the right speaker connection. The switch has 3 positions which can be selected. I had tried each switch position and power cycled the subwoofer each time until eventually i got a blue light on the receiver box.
You may also need to select the correct channel on the control box by pressing the "sound" button for 5 seconds on the remote control.
It took me quite a while to try the different combinations until it finally worked. I can't imagine that Philips would have sent the system out without testing the wireless partnership first, so I am guessing my wireless network could have had something to do with it. (forever the optimist).
I did expect the subwoofer standby light to have gone off or changed colour once operational, but this just seems to stay on no matter what state it is in.
Sep 09, 2008 | Philips Cineos HTS9800W System
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
Connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Jul 01, 2007 | Denon AVR-1507 Receiver
Philips MZ-7 CD Shelf System Logo
188 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
