Question about Refrigerators
S20BRSB21 AS THIS HAS A DIGITAL TEMPERATURE SETTING DO YOU THINK I NEED TO PURCHASE A NEW PRINTED CIRCUIT BOARD, IS THIS WHERE THE DEFROST SETTINGS ARE MADE? I HAVE SEARCHED FOR THERMOSTATS, TIMERS ON PARTS WEBSITE BUT I CANNOT FIND ANY FOR THIS MODEL? NICKY
  • 828 Answers
The printed circuit board is a rather expensive item and I would check or have checked the defrost heaters and defrost thermostat first to find if the problem is there. If there is no problem in the heaters or thermostat then go to the next step.
The defrost heaters And defrost thermostat is located behind the rear wall in the freezer compartment. They can be checked with an OHM meter for continuity. The shelving and the rear wall must be removed to access these items.
Posted on May 31, 2008
Fridge is warm freezer is cold
Hello Abo Karin,
You are likely experiencing a DEFROST failure
(most commonly a defrost PCB failure)...
part number 67006740 item 5 on your exploded
case view (top center as viewed from the front).
There are typically only three (3) elements to a DEFROST
power control circuit:
- Defrost Printed Circuit Board ( PCB as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per your DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
a PROPERLY functioning defrost circuit would remove that frost
at least DAILY... and the EVAPORATOR fan would properly chill the refrigerated side blowing cold air from the FREEZER.
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
Hope this helps
Your part... (see video instructions)
http://www.appliancepartspros.com/whirlpool-board-jazz-wpw10503278-ap6022400.html
Sears... (I don't USUALLY recommend for purchase)
http://www.searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Repair-Maintenance/Questions-Answers/location-of-defrost-timer-on-sears-fridg/Model-59665932402/0582/0161000/338616?modelNumber=59665932402
also see other .com retailers
partsselect,
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Apr 19, 2017 | Kenmore Refrigerators
Tip
How to choose a good PCB (Printed Circuit Board) manufacturer ?
RayMing - Your trusted partner
RayMing - In Asia alone, there are so many thousands of options when you want to select a printed circuit board manufacturer or fabricator, but which one is the best? RayMing has been in Printed Circuit Board industry and confident we offer the best combination of price, quality, on time delivery and customerservice to the customer. That is the reason we think that as a customer of Printed Circuit Board product, you should ask about PCB manufacturers to help youcompare and choose the best printed circuit board manufacturer for your company.
First factor: When selecting a quick turn PCB manufacturer or supplier, you need to look at how long they have been in business and how stable in term offinancial stability of the company. The printed circuit board industry is highly competitive especially in Asia and many PCB manufacturers come and goespecially in Taiwan and China. This causes your commodity manager or purchaser continue searching for Printed Circuit Board supplier which will costs youboth time and money when come to selecting a Printed Circuit Board company.
Second factor: Does your Printed Circuit Board supplier just take your order or do they offer value added services to ensure highest quality,
manufacturability, and performance accuracy of your circuit boards?A good quick turn Printed Circuit Board shop will offer extra value added services to go above and beyond their competitors. The obvious services like
additional cost savings proposal, extra reliability design, manufacturing assistance through the project, timely communications to ensure no surprises and noimpact in term of on-time delivery.
Third factor: Is your supplier follows new regulations and standards associated with RoHS compliance and lead free finishes?
While most other Printed Circuit Board companies were trying very hard to makes changes to meet RoHS compliance for circuit boards, you need to ask specificquestions and look detail into various industry standards that the Printed Circuit Board supplier has met. In Asia, ISO standard might be a good gauge. Anautomotive certification of a Printed Circuit Shop houses might be an additional value add to their capabilities standard that you can consider in your PCBsurvey list. refer
Quick Turn PCB for more information for quick turn pcb.
www.raypcb.com
on Jul 22, 2010 | Computers & Internet
Why is my Whirlpool s20brsb21 fridge not staying cold ,the temperature seems to vary and food is going off
The most likely fault is the relay on the rear board located behind the back panel , take out the plastic housing that contains the printed circuit board and take the lid off then switch the fridge on and listen for the compressor starting if after 15 minutes it does not start tap the big orange relay with a the handle of a screwdriver if the compressor starts you need to change the relay and associated capacitors, if that is not possible just change the complete board.
there are loads of other possibilities but that is the most likley
Aug 01, 2014 | Whirlpool Refrigerators
Whered can I purchase a printed circuit board for 8203 series spa and what is the cost?
OH is the Over-Heat event code. Not likely related to the board, this comes up for a number of reasons -
Flow issues cause the heater tube to get too hot. Dirty filter, suction blockage, low water level etc...
Hi Limit sensor has failed or the temperature sensor reading incorrectly.
Usually its a flow related problem
Aug 05, 2012 | Pool & Spa
Tt18hpxlt defrost timer
there is no defrost timer in this model,it is called an A.D.C. adaptive defrost control and is located in the refrige compartment just above and behind the cold control setting inside this plastic case,remove this case from the top of the refrigerator compartment and you will see a small printed circuit board,this is the A.D.C.
May 12, 2012 | Estate Refrigerators
Jenn-Air not cooling. Repairman replaced 'defrost control board.' Still not cooling. Control to set temperature will not move from zero. Any suggestions appreciated.
Generally when a printed circuit board faults it often takes out the other boards too.
You may need to get the main PCboard replaced too
Apr 01, 2011 | Jenn-Air JFC2087HRP Side by Side...
JENN-AIR MODEL D156B Electric oven
code f 0 means what?
Feb 11, 2008 | Cooktops
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Kenore freezer running constantly
need a model #.. is this a frost free freezer or a refrigerator ?
Sep 19, 2007 | Freezers
Open Questions:
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
