Question about Nikon D40 Digital Camera with 18-135mm lens
How do I set the resolution? - Nikon D40 Digital Camera with 18-135mm lens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Press the info button on the back to bring up the shooting information screen. The second item from the top on the right column is the image size. Press the button to activate the settings, then use the multiselector to navigate to the desired setting. Press OK, use the multiselector to select the desired size, then OK to set it.
Your choices are Large (3008x2000), Medium (2256x1496), and Small (1504x1000).
Note that you cannot change the image size if you're shooting RAW. The image quality setting is the one just above the image size.
Posted on Oct 11, 2010
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
I cannot get good resolution in my Hannspree HF229H, what can I do???
The resolution you should be getting is 1680x1050. Under Windows 7, right click on your desktop then open 'Screen Resolution'. If the resolution is set to anything other than 1680x1050, set it to that. If that setting is not available then it is possible that your video card does not support that resolution. This would only effect old computers. If the resolution is set to 1680x1050 but you don't have the proper resolution onscreen, try adjusting the monitor settings using the buttons on the bottom of your monitor. Hope this help and have a nice day!
May 02, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
How do I increase screen resolution in PC mode running Windows XP Pro?
To change your monitor's resolution
1. Right-click the desktop, and then click Properties.
2. In the Display Properties dialog box, click the Settings tab.
3. Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4. Click Apply to have the new resolution take effect.
5. If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6. Click OK.
Hope this help.
Mar 21, 2011 | Computers & Internet
The graphics are not normal,they are big.
First try changing the display resolution by going to display properties in control panel. Move the slider to the right. Hit apply.
If this doesn't help you out, it could be a display graphics driver problem. Try going to the support website for the laptop manufacturer and download the drivers for the display adapters.
Dec 08, 2010 | Computers & Internet
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
I have knocked a button on my laptop the screen has gone small i can not make it bigger i have been into properties but dont know where to go next
Position your Mouse on your Desktop. Just on the background. Right click. Select Properties. Select the 'Settings' Tab. You can select the resolution of "800 x 600" for larger icons or if you want more desktop area move to the right. I am set to "1400 x900"
The other setting you should look for is the Color Quality. Generally this should be largest number. IE 32 bit.
Jan 01, 2010 | E-Machines eMachines Desktop PC
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
Font and screan to big and fuzzy
Right click on your desktop. Click on properties.
Click on Settings. Adjust the resolution based on the documentation for your screen.
Jun 27, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Nikon D40 Digital Camera with 18-135mm lens Logo
41 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
