Question about Transcend USA 120GB Storejet 2.5" SATA - Titanium 120 GB USB 2.0 Hard Drive
0x80070037 error code appears while copying files to my 320 gb transcend harddisk and harddisk appears disconnected/connected repeatedly
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
I am using a software called Long Path Tool for such errors.
Posted on Oct 02, 2015
    Top Expert:
  • Transcend Master
  • 10,875 Answers
Bad cord
Posted on Jun 13, 2015
saqeb
  • 47 Answers
SOURCE: Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Posted on Jan 28, 2009
Damilare
  • 358 Answers
SOURCE: 320 GB transcend external Hard dics is not at all detected
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Posted on Nov 22, 2009
SOURCE: western digital passport drive (320 Gb) disconnecting randomly
These hard drives are flimsey and unstable, see how fragile the connector is, also incompatible if you want to plug into USB1 and old OS, made the mistake of buying one, and since bought a more sturdy Seagate external which is plug n play with everything.
Posted on Jan 03, 2010
KingDWS
  • 1606 Answers
SOURCE: Transcend hard disk issue
The problem is the usb ports in your pc. You know the drive works and is properlly deteced on the laptop so you can ignore that.
IF you can try other usb devices in your pc usb ports and see if they work.If they don't at all then you either have dead ports or drivers are missing. You should see them listed under control panel system hardware.
If they work then I would wonder if the usb drive you have requires a differant usb port than what you have. There is a type 1 and 2 and type 3 which has just come out so we can ignore that one. A type 1 is slower and cannot power devices usually. A type 2 is faster and can power some devices. I don't know how old your pc is so it could be hardware, either failure or drives. You should also makre sure you have the service packs installed for windows. Sp3 is the latest version. There were some changes to the way usb devices were deteced in Sp2 if I remember correctly.
Posted on Apr 13, 2010
  • 195 Answers
SOURCE: My External Harddisk 320 gb transcend not detected
I would recommend trying the fix on this page if you are running Windows XP
http://support.microsoft.com/kb/925196
Posted on Jul 08, 2010
I reformatted my Transcend 1TB hard drive as NTFS. It was successfully reformatted but when I try to copy files to it, it runs very slow. A 500kb file takes 1 hour to copy. Please help. Thanks!
please low level format it with a low level format software from hddguru dot com its free to use. please be careful as all the data is lost and is irreversible process.report us if the drive is still slow.
Mar 16, 2014 | Transcend StoreJet 320 GB USB 20 Hard...
My external hdd transcend 320 gb storejet is very slow while copying file to or from the hd and the blue LED keeps on blinking what might be the problem??
Well u may have it plugged in USB slot but needs to be USB 2.0 .if in regular. USB..will run slow...also external he'd when u not using. It unplug. From USB and AC plug...not good to just let run..they will were out..defrGment hdd to.good luck
Dec 21, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I am having a external 250 Gb transcend store jet Harddisk..it was working fine but after 15 minutes....suddenly it is saying that write protected ,,,i am not able to copy anything to harddisk and not able...
I HAVE THESAME PROBLEM WITH Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive ON MY VISTA 7..WHY THERE ARE no any hints or answers here ? so we can get help? thanks
Jul 29, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I can not copy more that 2 GB toTranscend StoreJet 320 GB? Why?
This is most likely because your hard disk is formatted using FAT32 which has a limitation of 2GB file size. Backup your data in another location and format the disk to NTFS and you should be able to copy that big file.
Mar 08, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have a 320 USB External Hard Drive i store the data it is fine but when i try to copy the file from external hard disk it is getting an error "Cannot Copy CZ9EXML" & it will disconnects i...
> cannot copy CZ9EXML
Is this a file currently on the disk-drive? If so, then the blocks on the disk-drive "owned" by the file have gone "bad" -- those blocks cannot be correctly read.
It's a little surprising that a "full" FORMAT did not detect those blocks as being "bad", and mark those data-blocks as "never-to-be-used".
Avoid trying to read that file.
This might be an "early" indication that your disk-drive is going to fail.
Do *NOT* keep the *ONLY* copy of your files on the Transcend!
Nov 13, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Jan 27, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Transcend USB is not working.
I have a 320 USB External Hard Drive i store the data it is fine but when i try to copy the file from external hard disk it is getting an error "Cannot Copy CZ9EXML" & it will disconnects i have reformated 2 times but no use
Dec 23, 2008 | Transcend USA 120GB Storejet 2.5" SATA -...
Transcend USA 120GB Storejet 2.5" SATA - Titanium 120 GB USB 2.0 Hard Drive Logo
4,041 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
