Question about Vacuums
Hello have a Hoover steam vac model F5906-900 serial #120500259649 use three times. The motor does not spin the brushs the square shaft does not move iam sure it is broke inside. thanks
    President:
  • 1,673 Answers
The turbine is what turns the brushes. If the shaft on top of the brush block is ok, then the turbine isn't working, you can try cleaning it, but replacing the turbine may be the best option.
Posted on Jun 01, 2008
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
I have a hoover f5914-900 steam vac.. and I was wondering if there's a way to take apart the spin brushes to get them cleaned out well. I loaned it to family, and the brushes came back extremely soiled and...
The brush block may be removed from the base for rinsing.
Yes, you can CAREFULLY disassemble the brush block assembly by releasing each of three latches that hold each of the clear gear covers to the main block. A small screwdriver is used to GENTLY lift each tab, one at a time. Pay attention to what position the special gear is at that has the drive pin (1/4 inch square drive) for correct reassembly.
Here is the link to the User Manual that shows how to remove the brushes from the base.
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Feb 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
MY HOOVER DUAL V STEAM VAC CARPET CLEANER BRUSHES WILL NOT SPIN! WHY?
There are three things to check:
Is the switch on the hood for brush speed set to full, or may it be set to OFF?
Remove the brush block from under the unit by pulling it down and unlatch each side. Is there a 1/4 inch square drive pin on one brush, about two inches long? It connects the brush to the drive mechanism.
Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replaced.
Oct 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes will not spin while locked in machine..
I have the same problem and think I know the solution.
The plastic pegs on the housing unit for the brushes have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you. Certainly is cheaper than replacing a motor or machine.
Aug 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Vacuums Logo
131 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
