Question about Canon BubbleJet i560 InkJet Printer
How do I clean ink pads on a canon i560 - Canon BubbleJet i560 InkJet Printer
  • 1 more comment
  • david72 Oct 11, 2010
    No that was not the problem. The problem is that I had the message that the used ink tank is full. I need to know how to empty tank which I think is a pad in a holder.
    My problem is I get an error message
    Used ink tank full on my canon i560.
    How do I empty the tank?
  • david72 Oct 15, 2010
    furtherther to the cleaning of the used ink tank.You have described how to cleqan the tank, all I need to do now is "how so I located the used ink tank"
    David72
  • Canon Master
  • 13,433 Answers
Hi
To clean the pads you need to remove them from the bottom of the printer. Wash them properly, wear gloves as your hands will be completely green or black or similar if you don't. Also your sink may become colorfull but you can wash it off.
after they are as clean as they come you need to dry them for 2-4 days until they are completely dry again and put them back in. You can actually purchase repalcement pads for example from ebay if you don't want to bother washing them, as it takes quite alot of time.
The printer will most likely still complain that the pads are full, a special reset is needed.
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Oct 11, 2010
  • Ekse Oct 11, 2010
    If the above did not work then do this:
    Canon i550, i560, i850, i950, i960 (May work with i860, i865)
    1. Start with the printer OFF
    2. Hold down RESUME and then hold down POWER
    3. release RESUME
    4. press RESUME twice, then release POWER
    5. Let green light blink until printer is done moving print head.
    6. Select functions below with RESUME press POWER to execute:
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    so on step 6 you would press Resume 3 times and then power to execute reset waste ink couter. If it didn't work try again.
  • Ekse Oct 15, 2010
    The tank, is more like pad. which is stored in the bottom of the printer. You can not easily replace or get this pad out. You need to take apart the printer some what, quite alot even.
    So you need to grab your screwdriver and start unscrewing the casing of the printer to get it apart.
    Are you sure you still want to do it? If you want guidance in each step of the way in taking apart the machine to get to the ink pads, please purchase a service manual http://www.2manuals.com/product_info.php...
  • 1,555 Answers
  • Press the "ON" button on the top of the printer, then wait for the green light located to the right of the "ON" button to stop flashing.
  • Lift the front cover up and wait for the print head holder to center itself. Note that the four ink tanks are contained within the print head holder.
  • Push the plastic tab on the front of the empty ink tank toward the cartridge to release it, then lift the tank out of the print head holder.
  • Peel the colored safety sticker off the replacement ink tank.
  • Pull the colored plastic cap off the bottom of the replacement ink tank.
  • Lower the ink tank into position within the print head holder, then press downward on the "PUSH" sticker on top of the tank until the tank clicks into position.
  • Lower the printer's front cover and wait a few seconds for the print head holder to move to the right side of the printer.
  • Posted on Oct 11, 2010
    How do I do a waste ink bypass to recycle ink from waste tank to avoid it getting full again?
    There is a small tube running from the pump to the waste ink pads. If you connect another tube to that, you would be able to run it out to an external bottle. Please note this won't stop the waste ink counter from doing it's thing.
    Aug 26, 2015 | Canon BubbleJet i560 InkJet Printer
    Black not printing
    Canon Bubble Jet i560 Ink Jet Printer not printing black
    Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
    Ink absorber
    Hi
    Try this see if work for you.
    Canon i560,
    Dont forget when you have time you will need to clean out the ink pads, or it going to over flow.
    1. Turn off printer
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    May 08, 2010 | Canon BubbleJet i560 InkJet Printer
    The waste ink well is full
    Reset Procedures for Canon i560 Printers
    1. Turn off i560 Printers
    8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
    9. Please remember at some time of other you will need to clean out the ink pads that are inside the printer.
    Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    Feb 22, 2010 | Canon BubbleJet i560 InkJet Printer
    My Canon i560 stopped printing- snall window
    That error says the purge assembly is not moving properly, check for paper stuck over on the right where the printhead parks, also if the squeegee is stuck over the cleaning pads you need to push it back to allow the pads to come up properly.
    Jan 10, 2010 | Canon BubbleJet i560 InkJet Printer
    CANON i560 INKS ARE MIXING AT PRINT HEAD
    Due to the wastage of ink in the cleaning proc the cleaning head and the mechanism had become clogged and by sealing the gause cover jelified the ink unableing the succtionto work the sugestion was to renew the mechanism unit ...TO DISMANTLE the printer rais the lid....the two ends must be levered carefuly from the back as you will see the front has a tiny lug holding them on ...it is a push-fit and click 3 hiden lugs hold the sides on ...use a thin bladed knife some damage may occur to them but there is no other way once loose pull the sides forward to take the light colour ""L" shape ends off the unit... this will expose 2 slots in the front and one each side near the back ...a flat tool gently pushed in 1/8th inch will release the top cover ...move the ink carrage to the centre psn exposing the cleaning pads ...I was unable to go any further as although lose the pads were sprung and was fitted to a lifting mech with a cleaning blade which scrapes the surplace ink from the suction unit simular to a mini silk screen blade...
    Dec 29, 2009 | Canon BubbleJet i560 InkJet Printer
    How do you gain access to the "used ink tank" on the Canon i560?
    Well Fay after much research, the best answers I've seen actually came from other experts on this website. The link below will take you to another Fixya page with several, very good solutions to the same problem you have. My personal favorite was soaking up waste ink from the pad with kleenex or some other absorbent material as you won't need to take apart your machine. You merely remove the ink cartridges and carriage to gain access to the pad/sponge that Canon calls it's waste tank. I do wish you well and hope you come back to let me know if you were able to fix your machine.
    Greg
    Fixya Waste Tank Solution for Canon Printers
    Nov 08, 2009 | Canon BubbleJet i560 InkJet Printer
    Used ink tank is full
    Dis-assemble and replace or clean the wastee ink absorbing pad. Rinse (lots of work) until it is very light grey. Dry and then re-install.
    Download and run the maintenance software to reset the counter in the printer.
    Oct 30, 2009 | Canon BubbleJet i560 InkJet Printer
    Canon i560 won't print properly after ink reload
    try to clean nozzels and run the alignement utilityt.
    Jan 21, 2009 | Canon BubbleJet i560 InkJet Printer
    Canon i560s printer - color problems
    I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
    Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
    Canon BubbleJet i560 InkJet Printer Logo
    306 people viewed this question
    old marine
    old marine
