Question about Whirlpool Calypso GVW9959K Top Load Washer
Cloths under the agitator
When washing fine fabrics they get caught under the agitator. I have to unbolt the agitator to retrieve them, and they are ruined.
Whirpool came and said I need a new motor couple and another part for $450. It seems the agitator has too much play. Get this. It will only solve it sometimes. Man said it was a design flaw.
Any comments would be appriciated.
  • Anonymous Jun 02, 2008
    How do I unbolt the agitator? I have a curtain under the agitator
  • 5,911 Answers
There was a noted problem with the Calypso washing machine involving the control board. The machine had a tendency at the end of the wash cycle to pull such a vacuum to remove excess water from the clothes that it would pull clothes under the nunator (wash plate). This cycle consisted of a 30 second drain that often pulled such a vacuum that clothing would sometimes become stuck. The manufacturer came out with a replacement control board that took the 30 second nunator cycle and reduced it to (I believe) 10 seconds. This was supposed to minimize the possibility of clothing damage. The part number for the new control board was 8571359. There should have been a service flash out on this, but I'm not certain. You can try to get in touch with Sears at 1-800-252-1698 to inquire about this. I don't know if the manufacturer will cover the cost of replacement, but they SHOULD. This was a KNOWN problem, so they should be familiar with the circumstances. Let me know if you decide to pursue it and see what they may have to say. I hope this has been helpful to you.
Posted on May 31, 2008
Simpson washing machine
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
How do I remove clothes from under agitator?
Believe it or not the agitator will come off. Look under the fabric softener cup. There should be a fastener (nut or bolt) to loosten. Give the cup a good cleaning while you have it off.
Once the nut is removed you can work the agitator off.
Jul 27, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag Bravo washers is staining my cloths.......any thoughts on what may be causing this?
the upper transmission seals bad its under the tub agitator and letting oil into the water called "wash back" you need to replace this seal and stains will disappear
Apr 06, 2011 | Maytag Bravos MTW6600T Top Load Washer
Fine garment caught under centralrotor has black mark on it , is this grease?
It is not grease. Under the agitator there will be a sticky buildup of detergent and dirt that has stuck to it. Overtime this buildup can become quite a lot. When your garment became caught up under the agitator, it was becoming stained with this buildup.
Jan 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My one year old son dropped a refrigerator magnet in our clothes and now the magnet is under the agitator. How can I remove this to retrieve the magnet and not stop up the drain?
Pull up on the fabric softener dispenser in the top of the agitator.
Set it aside.
Remove the agitator mounting screw from inside the agitator.
Pull up on the agitator base to remove the agitator.
Remove the magnet.
Reverse the above order to re-install the agitator.
Aug 09, 2010 | Maytag Legacy Series Top Load Washer
Lint on cloths after wash is there a lint filter in the washer and where do i find the lint filter
There is a fine screen on the bottom of the inner tub under the agitator. It is self cleaning every time it spins out. If you use too much fabric softener, the screen can get clogged. Fabric softener is hard to clean off and the screen is pretty delicate.
Jan 03, 2010 | Whirlpool LSR7333 Top Load Washer
Can't get the fabric softner cap off
Don't feel foolish as im sure your not the only one this has happened to. to remove the agitator cap you must lift it off, apply slight twisting to it while your doing this. soap can gum it up so you may have to use a straight screwdriver to assist you. once you have done this, there should be EITHER a set screw for an allen key on the SIDE of the agitator OR a 3/8 hex screw in the center or the agitator. there is a spring under this screw so remove both and the agitator should lift staight up. use an old belt underneath the base of the agitator for better results. i hope this has answered your question.
Aug 08, 2009 | GE WJRR4170E Top Load Washer
Agitator not agitating to wash cloths.
remove top of agitator remove plastic cap inside agitator housing. remove 7/16 in. bolt. lift out agitator
Jun 20, 2009 | Washing Machines
Sheet caught under agitator
the agitator comes out..... by simply taking off the cup that holds fabric softner, just pull upward if needed wiggle and pull. under that you will see a raised plastic piece the raised plastic pc is pulled of by using a pliers pull upward under this you will find a bolt 1/2 or 9/16 socket remove bolt and pull out agitator same way by wiggling and pulling upward
Jan 08, 2008 | Kenmore 98702 Stacked Washer/Dryer
Shoestrings wrapped under agitator
You will have to remove the agitator. Remove the softener dispenser from the top of the agitator and when you look down the agitator, you will see a 10mm stainless steel bolt. You will need to remove this bolt to remove the agitator. If there is no bolt, try pulling the agitator up and out.
Nov 03, 2007 | GE WPRB9220D Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
170 people viewed this question
Dan Webster
Dan Webster
Sal De
