Question about Hotpoint Washing Machines
Machine is completely dead. Fuse and plug ok.
  • Hotpoint Master
  • 1,527 Answers
Hello, have you checked the glass fuse inside the washer's power supply ,but beware if you put another one in and blows again then you have dead short , make sure you use the same rated fuse
hope it helps
regards
shaun
Posted on Oct 11, 2010
My washing machine hotpoint ultima wmd 940 is dead no power ,but the fuse in the plug is ok.
the mains lead normally goes to a connector block at the top of the machine then onto a mains filter both of these can fail ie burnt out connections ect check these out first remember to un-plug machine first
Nov 10, 2014 | Hotpoint Washing Machines
Indesit 1200 widl 126 no lights showing when machine switched on. Checked plug fuse is good
Hi Whalley
Are all fuses ok? kindly check your outlet as your power source and measure the voltage.
Jan 19, 2014 | Car Audio & Video
Power light is off. won't turn on.my washing machine completed a load of washing then i put another load in and it won't do nothing
hello you would have checked the fuse in the plug if ok then check the glass fuse inside the washers power supply if it's blown the make sure you use the same rated fuse. beware if it blows again then you have a dead short hope it helps
regards
shaun
Jan 23, 2011 | Washing Machines
Machine dead, not starting
hello, i take it you've checked the fuse in the plug if ok then check all the wire connections if ok then it's possible that the glass type fuse in the washer power supply may have blown. make sure you use the same rated fuse thanks
regards
shaun
Dec 04, 2010 | Hoover UltraCare HC6 150M Front Load...
Bosch KTR18424 Compact Refrigerator completely dead no display either fuse in plug ok
ok unit is dead . ck the power at the plug first . if ok then look for a bad connection to ref .. there is no fuse in the unit to prevent it from working . some times they do get stuck in defrost cycles and is so repl the A D C .. hope this helped mm.
Jul 22, 2010 | Bosch KTR18424 Compact Refrigerator
My sebo felix is completely dead - i have checked the fuse and that is ok
Most likely this is a problem with the flex. Quite often it gets damaged (simply wear and tear) - most commonly just where it leaves the plug or where it enters the machine, as these points are subject to the most strain and flexing. Unless you feel confident dealing with electrical problems, you are best advised to let a professional repairer look at the machine.
If you want more help, post a reply here, and I'll see what I can do. Good luck!
Feb 22, 2010 | Sebo Felix Classic Bagged Upright Vacuum
Unit dead after power surge Model Pv7451 tape inside unit
Sounds like a blown fuse. If the fuse is ok, then the power supply is completely dead, probably blew out the power IC. You should at least be able to get the tape out by simply manually turning the tape deck motor until the tape releases and exits the machine. It isn't always easy and can take a while to do if your turning it by hand, but it always works.
Mar 21, 2009 | Televison & Video
Karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Oct 17, 2008 | Karcher K2.26 Electric Power Washer
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Washing Machines Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
