Question about HP DESIGNJET T1120 44 Printer
My Hp Designjet T1120 fails to initialize. When mains is switched ON the Front Display Panel in the plooter illuminate without any display and the Power switch in the display panel flickers with green light. No noise, head movement ect are heared and the system as if in stand by mode. Biswajit Borah
  • HP Master
  • 1,121 Answers
Reset the formatter & check,,
Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. My Hp Designjet T1120 fails - 11_19_2011_3_40_14_pm.jpg
Posted on Nov 30, 2011
  • 2 more comments
  • Gabrielle Jan 27, 2012
    I am having a similar problem. Last night the screen appeared blank and frozen, but still illuminated. I tried turning the plotter on and off and pulling out all of the ink and connections in an attempt to reset it. The problem still persists and currently the if it is the "III" led is flash, with the other three lights being on. DO you have any solutions to this issue?
    Any help is greatly appreciated!!!
  • Cosmo
    Cosmo Mar 01, 2013
    Guys did anyone solve this? I have a HP DesignJet T1120 24" and am having the exact same problem ("I" light is on, "II" and "III" lights are off on the formatter board and i get an illuminated screen and flashing 'on' button). After speaking with HP support over the phone I bought a replacement formatter board only to find that this doesnt solve the problem. Very disappointing! And i just hope that they will take the part back or at least change it for another part. I am going to try next to replace the HDD and just pray its not the PCA board which i can replace myself and we have no one licensed in the country (Seychelles) to do it. Before I do though, is there something that I am overlooking that I cant try in the meantime? This is really a crappy situation to be in. It is almost getting to a stage where i have to throw the machine in the bin when its hardly ever been used.
  • Cosmo
    Cosmo Mar 01, 2013
    Hey Vinaya, you seem to know quite a bit about this printer and I am having trouble understanding your explanation so I was wondering what you would make of the errors I am getting (see attached pictures). I can rule out the formatter board as I have already replaced it and am getting the same problem. If it is the PCA board is this something that I can replace myself? Thanks for your advice :)
  • Vinaya Kumar Kuchipudi
    Vinaya Kumar Kuchipudi Mar 04, 2013
    Sorry for late reply...Light pattern indication "Formatter" faulty only. If you are getting same behavior even replaced genuine/good Formatte, some more exercise you need to do.. Are you ready?.. 1. Remove Formatter from printer slot,power on printer, check.. same behavior? Then its not Formatter/Hard drive faulty. Remove Formatter plastic panel, re-fix it in slot properly.. check (Due to bad assembling Formatter won\'t fix properly in slot).2.Check "Star Wheel unit", is it broken?remove star wheel connector, power on & check for the display.. 3.Remove service station(Q6683-60187) connector check.4.Remove all connector(ISS,Display,Trailing cable star wheel connector etc) on main PCA(Q6687-60057) Power on & check for the light pattern.Found different light pattern?.Power on after each connector connected to main PCA. Check for which connector faulty(If any electronic/motorized part draws more power, power supply unable to supply sufficient power to the printer, results malfunctions).5. Check power supply voltages.. If found low voltages, replace it.Even if you are facing any problem let me know.
Ok folks, for anyone who is reading this attempting to solve their own problem with the T1120 I thought I ought to clarify how I fixed the problem.
Despite error messages indicating that the problem was related to the formatter board, it was in fact the Main PCA board. Expensive to replace but i am just relieved that its working again. I wasted 18months and replaced the formatter board and the onboard HDD before managing to sort the problem out. I also had to get a technician in to change the part as its not particularly easy to do it on your own without a bit of printer expertise.
Good luck.
Posted on Aug 12, 2013
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Update firmware
firmware is not likely to cure this fault , this is usually the first and only sign of the power supply failing ( can you hear a gentle buzzing noise near the back cover?) does the display take a little time for the characters to light up- it may even throw up a hdd error on initialize .
after a quick check of the display panel my first stop would be change the power supply.
Dec 10, 2013 | HP DesignJet 1050c plus InkJet Printer
Error message 08:11
Usually is a bad Main PCA if the display (front panel) is plugged in correctly.
Check the flat cable under the display to make sure it is fully plugged in.
Parts replacement sequence as recommended by HP is:
Main PCA, then Formatter, then Front Panel.
Feb 24, 2013 | HP Designjet T610 InkJet Printer
Pls., help. my hp designjet 130 does only shows the busy icon on the display after pressing the power-on button. it will not even initialize
had the same issue with a designjet 100 plus. I downloaded the service manual, opened it up, reseated every cable (be careful with this). **** thing started up like nothing was wrong.
May 23, 2012 | HP DesignJet 130NR InkJet Printer
HP designjet t1120 show restart the printer if the problem persists call hp supporter code is 47.01
Star wheel motor unit faulty, most of the cases I found star wheel motor gear pinion are damaged,see the snap shot for the reference..Simply replace star wheel gear assm. Removing star wheel motor. Remove left cover,formatter, spittoon,star wheel..Pl see the snap shot to under stand how to remove star wheel unit... Perform star wheel test after replacing the unit....
11_29_2011_9_25_17_pm.jpg11_29_2011_9_26_09_pm.jpg11_29_2011_9_27_06_pm.jpg11_29_2011_9_27_42_pm.jpg11_29_2011_9_28_13_pm.jpg11_29_2011_9_28_49_pm.jpg11_29_2011_9_29_24_pm.jpg11_29_2011_9_30_09_pm.jpg11_29_2011_9_30_33_pm.jpg
Under stand the snap shots, do it care fully, every thing we cannot discuss. Best of luck...
Nov 26, 2011 | HP DESIGNJET T1120 44 Printer
Error 08:11
There is no communication between the Front Panel and the Main PCA.
You are going to need a qualified DesignJet tech to check out the cables
to the Front Panel and the Main PCA and to the formatter.
You could possibly need a formatter, Main PCA, Starwheel assemby, or a front panel.
Apr 10, 2011 | HP Designjet T1100ps Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Hp designjet 100plus
paste this address in your browser, you should get some help there.
http://welcome.hp.com/country/us/en/support.html?pageDisplay=support
Jul 17, 2008 | HP DesignJet 100 Plus InkJet Printer
HP DESIGNJET T1120 44  Printer Logo
1,388 people viewed this question
Seeker5211
Seeker5211
