Question about Apple iPhone Smartphone
Calibration is working on my iphone but only on the middle of the screen. the calibration is not working. could you please tell me how to fix the calibration or touch sensor on the screen,
  • 33 Answers
Normally, such of these strange issues in iPhone get resolved by resetting the iPhone (by pressing the Sleep/Wake Button and the Home Button both simultaneously after which iPhone restarts slowly with the apple logo on the screen). Please try.
Posted on Oct 14, 2010
My iphone screen cant touch ?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
Question mark appears on screen when I put a game inside of it.
  • Try calibrating the screen
  1. Turn the Leap Pad off.
  2. Now hold the question mark button for two seconds and then power the until on while still holding the question mark button down.
  3. The unit will power on and when you see the "calibration Screen" you can release the question mark button.
  4. Touch the crosshairs with the stylus and a large crosshair icon will appear in the middle of the screen.
  5. Touch this icon with the stylus and this will bring up the screen calibration procedure.
  6. Touch all 5 crosshairs as the appear.
  7. Press the "B" button to exit after completing the calibration.
Regards, Tony
May 11, 2011 | Leapster Learning System
After changing digitizer my 3gs is not calibrated. When I want to press a number for example, it takes the one next to it. Any advice?
the screen/digitizer you got may be for a 3G rather than 3GS compare the connector with that of your old one to see. the 3GS has a black plastic middle, the 3G one has more metal pins.
Feb 27, 2010 | Apple iPhone 3GS Black (16 GB)
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Feb 04, 2010 | Sony E-reader Portable E-book MP3 Player
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
How can i calibrate my phone
iPhone 3GS has a built-in digital compass that works just like a magnetic needle compass. The accuracy of digital compass headings can be affected by magnetic or other environmental interference, including interference caused by the close proximity of the magnets contained in the iPhone earbuds. The compass may need to be calibrated from time to time. iPhone 3GS alerts you whenever calibration is needed. To calibrate, hold iPhone 3GS in your hand and move the device in a figure 8 motion until the calibration screen disappears. The digital compass should only be used for basic navigation assistance and should not be solely relied on to determine precise locations, proximity, distance, or direction.
Nov 14, 2009 | Apple iPhone 3G
Auto rotate not working. g sensor calibration not
I have the similar problem on my touch HD. its vertical calibration bubble is not in the middle and pressing calibration is not fixing the problem. Auto rotate is also not working! Any one knows the solution??
Oct 25, 2009 | HTC Touch HD Smartphone
Iphone slide to turn off and slide to turn on is not working. i even tried to hold buuton on top and round button at the same time and that did not work.even tried running the battery all the way down and...
you will need to change the screen calibration,cause finger mode does not work on screendue to bad screen calibration,iphones have that problem always,repair cost for that will be around $150-200 in phone repair shop.please leave comment,vote,note.thankyou
Sep 13, 2009 | Cell Phones
Iphone touch-screen
sir whats ur model\????
May 28, 2008 | Apple iPhone Smartphone
IPaq won 't respond to screen calibration.
So far no fixes. It's just been collecting dust. I think it's a screen response issue, and will probably cost more to fix than to replace (at least for me) in my situation. I'm thinking iPhone....
Jul 08, 2007 | HP iPAQ RX3115 Pocket PC
Apple iPhone Smartphone Logo
1,502 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
