Question about Zanussi Washing Machines
Model FA 8023. How to reduce the washing time? Now it is taking 2.30 Hrs for completing the washing. Please advice
4 Suggested Answers
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
VtToolMan
  • 704 Answers
SOURCE: washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Posted on Jul 28, 2009
rickead1
  • 1998 Answers
SOURCE: On a short cycle (6) it takes 2 hrs to complete
did he check the water valve first to assure that hot water is going into the machine through the water valve you can check this buying using a multimeter and checking the voltage going to the vavle and disconnecting the hose on the inside of the machine to assure that hot water is coming in through the vavle please write me back with your finds thanks again
rickead1
Posted on Sep 03, 2010
Whirlpool AAA Class Dishwasher
FA - Aquastop error
Check water supply. Low water pressure? Does the machine fill up with water in under 1 min? If not, thats your problem. If this happens during wash cycle, it could be the intake valve for the rinse cycle that is your problem, if you hava doubble/tripple intake valve that is.
Feb 17, 2016 | Washing Machines
Please describe what does FA error mean? Were I can find this Aquastop switch?
check your pump is not blocked take bottom front panel off and unscrew it
Jan 18, 2013 | Whirlpool AWM8123 Front Load Washer
Operating time is greatly reduced
check if there's no timer on you can set.or see if dispencer is clean,
and filters.see manuel where to find it
Jul 29, 2012 | Dishwashers
Extremely long cycle
The drying coil that is broken also heats the water during the wash and rinsing phase. Right now it is waiting for the water to heat up, that's why it's pausing. Replace broken heater, they are relatively cheap and can be gotten at repair clinic.com.
Feb 16, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
May 22, 2008 | Whirlpool AWM8143 Front Load Washer
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
