Question about NetGear DG834G Router
Please can you help. I have a netgear router dg834g and require a pin in order to connect my laptop to the wireless router. I have a Belkin router and the pins are printed on the bottom of the router. I remember when a software guy came to connect us up originally he used on of the numbers of the your router but I can't figure out which one it is?? Can you help Sue Nicolle
  • 71 Answers
SOURCE: Can't print using HP C6180 Printer via DG834G router
I helped a friend with this problem. He had Vista and was running through a Linksys router. You could see the printer, access the webserver through Internet Explorer by browsing to the IP (192.168.1.X), but the print job would hang, but would kick off immediateley if you reboot, but after it came up and printed that one job, it wouldn't print again. Here is the fix:
Find the IP of the printer and the exact name, which you should be able to get from browsing in Internet explorer to the IP. I think its under the farthest left tab and the 2nd option on the sidebar. I renamed it to HPC6180 because the original name was something like HP92601345U.
Now right click on the start button and click properties and select Classic Start Menu and click Apply/OK. (You can change this back later)
Click on the start button again and click Run and type in "drivers". When that folder opens up, go into the "etc" folder.
Right click on the file named "hosts" and click properties and uncheck "Read Only"
Then double click on the "hosts" file and open it in notepad.
Go down to the first line that isn't commented, it should say something like 127.0.0.1. Position your cursor on that line and hit enter to move 127.0.0.1 down one row. Then enter the IP address of your printer. Space over and line up with the entry below and add the Host Name (mine was HPC6180).
Click file and Save As, and in the file type, change it from .txt to "All files" and click ok, and click OK to overwrite existing file.
Close all your windows and reboot and try to print again. It should work now.
Posted on Jan 10, 2008
  • 101 Answers
SOURCE: Netgear DG834G Setup
Hi Tradeboy,
This link should walk you though it, step by step!
http://www.geekgirls.com/windowsxp_home_network.htm
If you are using Vista, you will probley want this link, too. Click on Network icon.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
In the past I have found the biggest issue with networking is firewalls, so I suggest you disable them just for testing and setting up your network.
Good Luck
Posted on Jan 11, 2008
jeromeboy
SOURCE: Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Posted on Jun 26, 2008
  • 35 Answers
SOURCE: Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Posted on Mar 19, 2009
wykidtech
  • 99 Answers
SOURCE: WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
Posted on Mar 21, 2009
I have Netgear DG834G v3 working fine on 3 laptops (vista) 2 iPhones ps3 and wii with wep and no issues. I bought a new printer which requires wpa to be used but when I change over nothing will connect....
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2011 | NetGear DG834G Router
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
Can I extend my internet range with a netgear & a Belkin router
DG834G is a modem/router, it is not a range extender that could extend the range of the wireless signal from the Belkin router.
Feb 07, 2010 | NetGear DG834G Router
Need help on wireless netgear dg843g router. light for wirelesss is staying on but the laptops take there time to conected and wont connect to router. what can i do, how can i connect my laptops to the...
To set-up a wireless connection on a laptop please click on this link for my instructions :-
The configuration URL for Netgear wireless routers is http://192.168.0.1
the default login = admin
the default PW = password.
Dec 13, 2009 | NetGear DG834G Router
Connecting another laptop
You can connect your friends computer easily to the router. Whenever your friends wireless switch has be switched on it wil detect the router and it will ask for the password to connect to the router. Hope you knows the password , by giving the password you can easily connect the system to the router
Please rate my solution
Thank you
Oct 22, 2009 | NetGear DG834G Router
Don't have home phone and looking to buy router/modem.
Yes it requires a phone line for AT&T, or a cable modem, or a community wireless modem to hook up to the internet
May 08, 2009 | NetGear DG834G Router
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
Oct 28, 2008 | NetGear DG834G Router
NetGear DG834G Router Logo
163 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
