Question about Compaq Computers & Internet
When trying to power up my Compaq nx6325 laptop, I only see the power light flash four times and then nothing happens. I have tried a second power source with the same effect. Any ideas please?
  • Martin Snow
    Martin Snow May 11, 2010
    Have you tried either power source with the battery removed from the system. The charge controller could possibly be bad telling it "empty" no matter what.
    If it turns on without battery, seal the battery in a freezer bag with no moisture and as much air squeezed out as possible for about 4 hours. then try putting it in and see what happens (just make sure no moisture reaches the battery. Lithium explodes with water contact)
    Sergeant:
    Champion:
  • 326 Answers
The biggest mistake people do is not sysle the battery. A laptop cannot be left on, and plugged in all the time like a desktop. Turn it off if not in use and when using run the battery all the way down every so often. U may have to buy a new battery, so keep these things in mind. Also, ventilation is very important. Though it is called a laptop, soft surfaces inhibatit the cooling systems ability to keep it cool. The more powerful the laptop the hotter it gets. Heat will shorten the life of all the devices of a laptop including the battery.
Good luck
Posted on Jun 01, 2008
Hi. My Compaq v2000 went into hibernation mode because the battery power got low, now I can't power it up using the a-c cord. I can see that power is getting to the notebook because one of the indicator...
If the power has been removed whilst in hibernation mode you may have lost your data that was not saved.Plug the power lead in and try rebooting in the normal way when you are in close down properly and refit the battery.
Feb 23, 2015 | Compaq Computers & Internet
My nx6325 laptop suddenly stopped working. Now when I plug in the power adaptor, the front light flashes once and then when I press the power button, the front light flashes eight times - then nothing,...
It probably has bad caps in side the adapter as shown here:
http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/?action=view&current=badcaps2.jpg
Voltage checking is the first rule in electronic troubleshooting, sorry to hear you had to take it all apart, live and learn. It will help you in troubleshooting any electronics next time.
Jan 09, 2011 | HP Compaq nx6325 Notebook
How to reset laptop compaq nx6325 bios password
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Nov 30, 2010 | HP Compaq nx6325 Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Power light flashes laptop does not power up
Sounds like your power input has failed. You will have to open up the machine and check it out. Get it checked professionally as it is a pain to sort out.
Jan 05, 2010 | HP Compaq nx6325 Notebook
No screen on start up
Did you replace both modules?
There is one more under keyboard.
Try external monitor.
Apr 14, 2009 | HP Compaq nx6325 Notebook
Compaq laptop won't turn on
Take out the battery completely and only hook up the adaptor and see if it turns on then. If it turns on then your battery is bad. If you try both adaptors and get the same flashing lights then the motherboard is bad.
Feb 04, 2009 | HP 435768-001 - Compaq Presario C300...
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
131 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
