Question about Alpine MRP-M1000 Car Audio Amplifier
I'm helping a friend service his Alpine mrp-m1000 amplifier. So far I found burn spot on an integrated circuit it has a KDY that reads up and down the it reads 600K then underneath that number it reads 849. I know these are part numbers I just would like to fix and and rock out, or is there a replacement part. Have picture of part available
  • kenw392
    kenw392 Oct 11, 2010
    there should be a location number on the board, example: ic 801. what is it?
  • garyyounger Oct 11, 2010
    It's a diode or a transistor. I'm thinking it's a diode because it's on the dc to ac portion of it. If I had a schematic of the logic board or a service manual I would good.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
There should be a number on the board beside the part, can you tell me what it is? example ic 801, d103 .
Posted on Oct 12, 2010
Alpine MRP m1000
Q4901 is a ktd600k. The actual alpine part number is 48E39128S01. If you are in the U.S. it can be obtained at pacparts.com.
Oct 31, 2012 | Alpine MRP-M1000 1000W RMS, Class D...
I have the MRP-M1000 amp. I want to hook up 2 alpine subs to this amp. Which alpine subs would be the best for this amp? Please be specific with ohms and watts.
Your best bet will be to wire 2 subs in parallel to the amp. Each sub should be rated for at least 300 watts rms at 4 ohms. This will give you a total impedance of 2 ohms, and your amp will put out 600 watts rms at that impedance. That way, each sub will receive 300 wats rms. I would not recommend wiring subs in parallel, as you will need two 1 ohm subs at 300 watts rms, which are harder to find and will be more expensive. A parallel circuit is the most efficient way to do it.
Feb 23, 2011 | Alpine MRP-M1000 Car Audio Amplifier
I have the Alpine MRP-M1000 amp. I want to use 2 subs with this amp. Which Alpine subs would work best with this amp?
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Feb 22, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
There is a smell in my car every time I play my system for long periods of time. Its a burning smell. Everything is wired correctly and I have a separate battery in the back of my car to power my subs. I...
The problem could either be the amp over-heating or the subs could be over-heating as well. One of my friends owns an Alpine MRD-M1005, and one day they decided to clean it inside and out and realized they had some burnt spots on the circuit board, although they never smelt anything burning, and the amp still works fine.... As for the lights dimming you should probably buy a power Capacitor, atleast a 1 Farad or larger.
Hope this helps.
Nov 08, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Hi ive got a alpine mrp-m1000 it lights up no sound was woking fine in the car didnt use car for 3 months then i wouldnt work all wires are fine and so is the sub please help
If your not getting any sound make sure the sub input is in the right spot on you radio. if not check the speaker wires on your harness
Feb 14, 2010 | Alpine MRP-M1000 Car Audio Amplifier
How do i hook up the mrp-m1000 to 2 type r subs since it is a one channel amp? the subs r 4 ohms so it should work right?
hook the positive to positive and negative to negative on both subs then run wire to the amp the amp will see a 2ohm load
Jan 07, 2010 | Alpine MRP-M1000 Car Audio Amplifier
How do i install mrp m1000 to two type r 12s step by step.
Hello chadbcavanau,
See the link here for a step-by-step install with photos and amp wiring diagram.
First you need to purchase an amp wiring kit (minimum 4 gauge power and ground). If your vehicle is equipped with the stock radio, you'll also need to purchase a line output converter (LOC).
Hope this helps.
Sep 23, 2009 | Alpine MRP-M1000 Car Audio Amplifier
No light on Alpine MRP-M1000
Ok. Have you check the Ground and the Power connection.
Jan 25, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Alpine MRP-M1000 Car Audio Amplifier Logo
206 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
