Question about LG Washing Machines
Washing machine Model LG WD16117FD Problem: the motor get's power but when it starts do turn, it block's, and dosn't turn. Is the problem the motor or the electrical controls?
    President:
  • 1,554 Answers
The problem is the motor itself because the rotor is locking up and the only viable solution is replacing it.
Posted on Oct 11, 2010
I have a LG washing machine,model WD1256RD that won't power up I've changed the main power board no joy.
did u check for a fuse as some of the newer models have a fuse sometimes located along the body or tub ? it may have bad fuse, also check for live voltage where the power plug wire attached to the motor . Your schematic should show which wire from the motor is the live wire. There 2 wires u can jumper with a test plug with 2 stripped back wires and a prong at the other end, when plugged in and attached to ur motor it should start, if it starts then ur power cord is bad. This is a live power test with a multimeter to check for proper voltage. as you may not be getting voltage to the unit
Nov 25, 2016 | LG Washing Machines
My Beko Washing Machine isn't responding. Can you help me fix it?
TURN IT OFF!
The motor is bound and if you continue to power it, you will burn out the motor windings. You have to locate and free whatever is binding up the motor. That will resolve the issue.
Bet that if you disconnect the motor from the mechanics around it, the unit will turn.
Jul 13, 2015 | Beko Washing Machines
The SE light flashes when turning on the washing machine
Not sure which washing machine you have. But assuming it is an LG SE is a serious fault.
Motor fault detected Can also be caused by be main PCB
This is not a good fault code to see as it will generally be correct and either the washing machine drive motor or the main electronic control PCB is faulty.
  • Check motor
  • Check motor tacho
  • Check all connections and blocks to the motor
  • Check connections on the main control module
  • Check main control module
For more detailed analysis please post make and model of your washing machine in the comments field.
Sep 26, 2014 | Washing Machines
LG 7kg wd 8015c
possibly the lid switch when you put the lid down is bad
Nov 09, 2013 | Washing Machines
Washing machine drum won't turn under power
is the washing machine went to its usual cycle? put water in?
if you think the motor should have run already, then it could be the motor or the motor inverter.
check the motor leads for equal resistance, if i'm right, you may have a three phase motro so the three leads that comes out should have equal resistance.
also, if you can monitor the voltage present in the motor leads while it is plug in and you are waiting for the motor to run, if there is voltage then there is a problem with the motor, if there is no voltage present, then the inverter unit would be the defective part.
tnx 4 using fixya,
drcool
Sep 28, 2008 | LG WM-2077C Front Load Washer
LG washing machine Model WD 1433RD
I had the same problem. I thought it was the motor it turned out I had a nickle wedged in the filter (bottom left behind panel) the nickle blocked the water pump makeing the pump overload.
Sep 15, 2007 | Washing Machines
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
