Question about Maytag PAV2300 Top Load Washer
The TIMER nob of my Maytag-Top Loader washing machine is not working properly. It usually get stuck. To be more specific, the lower nob is rotating with the upper nob. And it is very difficult to turn around. I bought the machine from KSA (Model No.4KMTW5755TW) on 11.11.2009 and brought the machine to India. Now the machine is working, due to the timer problem, we are not getting the full advantage of the machine...What should I do now. please answer ...
  • aalthaf Oct 11, 2010
    the lower nob is NOT rotating with the upper nob... please pardon
ttech
  • 139 Answers
SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Posted on Jul 20, 2007
  • 641 Answers
SOURCE: Maytag Atlantis MAV6257AWW
Well done !
Posted on Jul 30, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
docjohn174
  • 943 Answers
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
JR JR
  • 116 Answers
SOURCE: Washing machine will not spin dry but washes properly
CLUTCH MAY NEED TO BE REPL/ IF DOES NOT SOLVE REP/ TRANSMISSION
Posted on Nov 30, 2008
How to trouble shoot maytag timer nob
There is still water in the machine , the pressure sensor my not be operating there is a loose contact in the motor spin winding or the timer no supply voltage is going to the motor check the votlage at the motor at spin cycle
Sep 20, 2012 | Maytag SAV3710AWW Washer
Top loader 600MB fills water but wont wash or spin.Water fills to right level and timer turns o.k.
Check the lid switch for proper operation. If the switch is bad or not being actuated by the lowered lid, it will block operation of the machine.
Oct 20, 2009 | Hoover HTC243 Top Load Washer
I have a top loader maytag washer which doesnt want to spin on the spins cycles or will it agatate? any ideas
Usually the machine will not spn because the lid switch is not working properly. It could be stuck or broke. Do you hear a clicking noise when you raise and lower the lid? If its not doing either spin or agitate could have a bad transmission, motor, belt, etc
Sep 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My maytag top loader washer won't spin but agitates,what is the problem
Maybe a sock stuck between the two tubs. If it has not dropped down too far you maybe able to feel it. Open the lid and pass your fingers gently between the two plastic tub covers. The lower cover moves with the inner tub while the upper stays still.
Jun 21, 2009 | GE WBSE2090A Top Load Washer
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My maytag washer just stopped working...
Manually open the timer switch component rotate the knob forward and it will work. / rotate inline w/water fill full keep near the timer you can hear the timer running or not / if not the small motor of timer need to replace availqble in appliance service center,.
Dec 16, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Mav7200-57-58
The timer itself is bad, replace and wala! Timer Part Number: PT756240 Made by MAYTAG http://www.partstap.com/partsearch/model.aspx?model_id=47859 $70.22 + S&H
Sep 16, 2007 | Maytag MAV7600 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
