Question about Rheem Water Heaters
Rheem integrity 26 code error c9 12 - Rheem Water Heaters
2 Suggested Answers
  • 68 Answers
SOURCE: Rheem Integrity 24 Has Error LO79 can someone tell
79 is fan motor current fault or circuit board you will have contact rheem
Posted on Aug 12, 2010
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
Rheem Integrity 20 not always lighting. Showing code C2 11
Before calling service technician, open following links for Rheem/Paloma troubleshoot resources including error codes:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
C2 11 is no ignition.
Clean combustion parts yearly as recommended in manual is first step.
Other causes can be loose wiring, bas gas valve, dirty air intake, bad venting, bad sensors etc.
Test these parts using service manual. Call Rheem since Rheem does not post service manuals.
Oct 06, 2011 | Rheem Tankless Hot Water Heater...
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
I have a Rheem rtg 74dvp but its not heating and the display show me 1 76 and 2 76, and come all the time to 76 F and another times its blinking the temperature, but not heat
Error code 76 is communication problem between remote control and tankless unit.
Multiple error codes could indicate that main PC board is bad.
Before calling service technician, open following link for troubleshooting resources including link to Rheem chat, manuals, error codes, etc.
Jul 15, 2011 | Rheem Tankless Water Heater RTG-74DVP...
Rheem tankless water heater eco180-dvn has flash error code 13. Any solution? Called Rheem, only said venting problem, wouldn't provide the next step. Thank you.
Rheem wants customers to call trained service technician since error codes are start-place for troubleshooting, and problems can be combination of issues.
Risk of CO poisoning from improper vent, or clogged drain line causing damage to heat exchanger, and risk of homeowner working on complicated gas-burning appliances are reasons why Rheem instruction manuals recommend yearly maintenance by trained technician.
That maintenance would typically cover most common error code issues, and homeowner could gather tips and information from service tech.
Open following links for Rheem troubleshooting resources:
Jul 12, 2011 | Rheem Water Heaters
Jun 07, 2010 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
300 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
