Question about Fisher and Paykel Fisher & Paykel Washer
Hi I have a gw612 Fyscher and Paykel 8 years old. It is now refusing to start and the led lights when I turn it on are the third and the fourth wash cycle lights as well as the spin light. If I press start the lid locked light comes on.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Starting from the left to right if the lights that are on when the machine is beeping are the 3rd and 4th and 8th then the error code is called COLD VALVE FAULTY.This means either your cold water valve is faulty or you control module is faulty.Would you like me to guide you in the testing and isolating the fault and replacing the faulty component?Please reply for further help.Looking forward to your reply.
Posted on Oct 12, 2010
  • 2 more comments
  • kimm756 Nov 10, 2010
    What was the outcome for this problem?
  • cjr316 May 22, 2011
    how do you fix it??? we are having the same problems
  • luisa_sgro May 23, 2011
    Hi just read your posting.Do you have or can borrow an electrical test meter?You will need this to test the water valve.Please reply with additional information and I am sure I can help you.
  • Hiri pouwhare Jun 10, 2013
    I have the same problem but i dont have an electric tester or know how to use one?
Hi I have a F & P washing machine GW612. It has the seventh light come up in diagnostic mode. Is that error 2 & how do i fix it please? Thanks
Here is the instructions manual which contains the detailed diagnostic code explanations from p.33 on.
http://laundry.manualsonline.com/manuals/mfg/fisher_paykel/gw612.html
Aug 26, 2015 | Fisher and Paykel Washing Machines
I have replaced the cold water valve on my F&P GW612, it worked well for about 6 washed and now is beeping continuously and LEDs are on (00110001). I cannot get the machine to power off without...
Hi Deb.
Unfortunately there is no really easy answer to your problem without getting a technician out.
When you ring it would pay not to tell them you've been working on the machine yourself or they may refuse to work on it.
Just say that the light are flashing..etc.
Bear in mind that the Hot and Cold valves on F&Ps are different and should not be exchanged.
Good luck.
Nomess
Jan 29, 2015 | Fisher and Paykel Washing Machines
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
F & P Washer GW612 Wont drain fully unless you repeat spin a couple of times and then wont rotate have taken motor to be tested was (low?)Have replaced no improvement First and fourth light flash and...
Kate - firstly the windings of the stator when measured is 32 Ohms, earlier models was a lot lower between B-Y-R.
The washer will pump - rest pump (Cycles) during the spin cycle, if however it overheats then water will not be fully pumped out. A possibilty is the hose into the drain or sink is too high, or blocked somewhere.
In most cases the washer will indicate an error code.
The LEDS 1st & 4th from the right im assumming 10010000 = Fault code 144 - either you have a loose connection under the display/push buttons panel or you have a faulty motor control module
May 11, 2011 | Fisher and Paykel Fisher & Paykel Washer
Tub fills but there is no aggitation model gw612
Hi just read your posting,Now, does the machine show an ERROR CODE and beeps?If it does show an error code it will be in a number in your LCD DISPLAY if you have that model or a series of lights will light up.Now these lights will be in a row of 8 lights.Starting from the left to the right which ones are lit when the machine beeps?Is it the 2nd and 4th or the 1st and 5th ---etc---?Please reply with additional information and I am sure I can help you.
Aug 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
The washing machine fills with water but then appears like it struggles to spin and then it stops attempting to spin, then starts to beep and flash lights. the lights that flash are the middle green...
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Jul 30, 2010 | Fisher and Paykel Washing Machines
Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
583 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
