Question about LG Refrigerators
Our lg grs512gc fridge stinks, we think the drain hose could be clogged. Its not the contents and we have thoroughly cleaned the fridge. how to unplug?
  • 4,793 Answers
Use a syringe filled with clorine bleach to clear any drain holes.the smell will dissipate very quickly if the door is left open for 10 mins.
Posted on Oct 11, 2010
Fridge drain hole blocks with ice every few days, fridge icing up inside too. I've tried defrosting thoroughly manually.
Check your drain line for clogged .Clean it out .
To verify that it's clean pour water in drain line and you shold see water coming down into a drain pan at the bottom
Jun 01, 2017 | Refrigerators
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I've disconnected the power to an extra fridge I do not want to use right now. Will it be a problem leaving the doors closed?
Yes it will,when you go to open it again, it will stink.....unless you thoroughly clean out with neat clorine bleach,every nook and cranny,door seals/drains the lot..put some bicarb in a cloth bag to "soak up" any musty smells.
Sep 09, 2010 | Refrigerators
Towels smell sour. while cleaning noticed small "hole" (factory made) in bottom of boot in front of three "notches". seems like a drain hole? stuck q-tip in there and stinky black muck discovered. ran...
I think you are talking about the door gasket. Use a mixture of bleach and water in the gasket and also in the drum. Most front load washer are notorious for mold and mildew. Run the washer in a rinse cyle to clean drum. Also clean your drain filter.
Jan 06, 2010 | LG WM2688H Front Load Washer
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Refrigerators
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Maytag Dishwasher won't drain
on all dishwasher think of them as a simple gutter system. the water only has one drain. At the bottom, if the pump can't pump out the water, its simply a bad pump or a clogged drain hose. Food particle can clog the "drain screen", use a good quality shop vac, clean 'drain screen', remove drain hose and clean thoroughly. If the hose goes into your drain pipe, remove that and clean that really good with snake it its metal or a strong 1/2 zip tie if its plastic.
Nov 30, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Code OE water is not being drained out
You may have a broken or plugged drain pump and needs to be diagnosed by a qualified LG technician.
Jun 26, 2008 | LG WM2277H Stainless Steel Front Load...
Want suck
some form of blockage in hose
Oct 22, 2007 | Bissell 6594 PowerForce Bagless Upright...
Refrigerators Logo
338 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
