Question about MSI K8MM-V Motherboard
MSI MS-7142 motherboard problem is not support 500gb sata hard drive
    Guru:
  • 124 Answers
Your motherboard can connect up to 2 serial ATA devices and for this reason, it can support a 500GB sata hard drive.
Posted on Oct 12, 2010
Ms 7142 sound driver
Dear,
From the link : http://www.driverscape.com/manufacturers/msi/laptops-desktops/ms-7142/879
you can find all drive for your motherboard
Thanks with Regard,
Ankur Goyal
May 07, 2014 | MSI K8MM-V Motherboard
Will K8MM-V MS-7142 Motherboard supports 500GB/250GB Sata 3(6gbps) Hard disk, by setting to 1.5gbps speed ?
The designers of SATA aimed for backward and forwardforward compatibility with future revisions of the SATA standard.[citation needed] To prevent interoperability problems that could occur when next generation SATA drives are installed on motherboards with legacy standard SATA 1.5 Gbit/s motherboard host controllers, many manufacturers have made it easy to switch those newer drives to the previous standard's mode. For example, Seagate/Maxtor has added a user-accessible jumper-switch, known as the Force 150, to enable the drive to be switched between 1.5 Gbit/s and 3 Gbit/s operation. Western Digital uses a jumper setting called OPT1 Enabled to force 1.5 Gbit/s data transfer speed (OPT1 is enabled by putting the jumper on pins 5 & 6). Samsung drives can be switched to 1.5 Gbit/s mode using software that may be downloaded from the manufacturer's website. Upgrading a Samsung drive in this manner requires the temporary use of a SATA-2 (SATA 3.0 Gbit/s) controller while programming the drive.
May 09, 2012 | MSI Ms-7142 k8mm-v Mainboard Ide - Socket...
Will K8MM-V MS-7142 Motherboard supports 500GB Sata 3(6gbps) Hard disk, by setting to 1.5gbps speed ?
The designers of SATA aimed for backward and forward compatibility with future revisions of the SATA standard.[citation needed] To prevent interoperability problems that could occur when next generation SATA drives are installed on motherboards with legacy standard SATA 1.5 Gbit/s motherboard host controllers, many manufacturers have made it easy to switch those newer drives to the previous standard's mode. For example, Seagate/Maxtor has added a user-accessible jumper-switch, known as the Force 150, to enable the drive to be switched between 1.5 Gbit/s and 3 Gbit/s operation. Western Digital uses a jumper setting called OPT1 Enabled to force 1.5 Gbit/s data transfer speed (OPT1 is enabled by putting the jumper on pins 5 & 6). Samsung drives can be switched to 1.5 Gbit/s mode using software that may be downloaded from the manufacturer's website. Upgrading a Samsung drive in this manner requires the temporary use of a SATA-2 (SATA 3.0 Gbit/s) controller while programming the drive.
May 09, 2012 | MSI K8MM-V Motherboard
Good day sir how do i connect a 500gig sata drive to a mother board ms 7142
Dear User, Good day, This is the specification of your motherboard. MSI K8MM-V Via Socket 754 MicroATX Motherboard / Audio / 8x AGP / 10/100 Ethernet LAN / USB 2.0 / Serial ATA. All you need is sata cables and an adapter if the power supply cable support only serial IDE. check this link for the photo of the adapter. http://www.buy.com/prod/ide-to-serial-ata-sata-for-3-5-hdd-pc-adapter-converter/q/sellerid/23962916/loc/101/214950013.html
Apr 16, 2011 | MSI K8MM-V Motherboard
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Dec 30, 2009 | MSI K8MM-V Motherboard
My new 500GB WD SATA internal hard drive isn't recognised
Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
Nov 19, 2009 | Computers & Internet
Need of motherboard driver ms-7142
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
Hope this helps...
Sep 19, 2009 | MSI K8MM-V Motherboard
I need MSI-ms-7142 ver:1 audio driver
i have no sound. So i need audio driver. Please send ms-7142 VER:1 audio driver
Jun 12, 2009 | MSI K8MM-V Motherboard
SATA 2 HDD
I think, one possible way is to manually force sata 2 (there is no such thing as sata 2) to sata 1 by using a jumper for the hard drive. For exact details, please consult the sticker on the hdd or contact the hdd manufacturer for firmware updates. And please report back, especially if it's a success. (Damn, the VT8237)
Jun 05, 2009 | MSI K8MM-V (MS7142-010) Socket 754 Micro...
MSI K8MM-V Motherboard Logo
385 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
