Question about Kenmore Washing Machines
OLDE WASHING MACHINE LEAKING AFTER FINAL SPIN BUT NOT ALL THE TIME
SO OUR LAST WASHING MACHINE DID THE SAME THING FOR A WHILE THEN BROKE DOWN. A FRIEND SOLD ME A USED OLD KENMORE AND IT WAS FINE FOR A FEW WEEKS BUT IT'S HAPPENING AGAIN. NOT ALL THE TIME BUT AFTER THE FINAL SPIN THE WATER TRICKLES INTO THE WASHER. I HAVE TO TURN THE WATER OFF SO THE MY CLOTHES DON'T GET SATURATED BEFORE I THROW THEM INTO THE DRYER
  • lindsayP May 31, 2008
    no it is a 2000 top loader. it never leaks until the final spin is over then when i go to get my clothes out i find that the water has been leaking slowly i have to turn the water off and re spin. now this happened with my last washer and it eventually broke.
  • prem mathew May 11, 2010
    Is this a front loader, you shd hv mentioned.
    President:
  • 1,294 Answers
Not too familiar with top loaders. With front loaders good pressure is required to keep the inlet valve closed, when not in operation. If the pressure is not there water leaks even when the machine is off. The problem cld be with the pressure from your faucet or your inlet valve; mysterious why it happens after the final spin, & your second machine.... I can't be of much help here. You hv to surf......
Posted on Jun 01, 2008
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Water leaks during final spin cycle only
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Aug 09, 2009 | Fisher and Paykel WA37T26G Top Load Washer
During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Aquarius WD420 washing machine won't spin and drain
same thing happened to me called engineer over flow pipe was blocked hope this helps anyone with this problem
Mar 04, 2008 | Washing Machines
Washing Machines Logo
97 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
