Question about Bosch 24 in. SHU43 Built-in Dishwasher
Where would I find the serial number/name of the exact Bosch dish washer I have. Have lost the monuel!
  • 10,865 Answers
Hello. look at the schematic below to see all of the possible locatioins
Dishwasher
Where would I find the serial number/name of the - dishwasher.jpg
Posted on Oct 13, 2010
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
Sep 10, 2014 | Washing Machines
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Bosch shu6802UC/06 use and care manual
Google and you are sure to find it. By the way, what is wrong with your dish washer?
Oct 17, 2013 | Dishwashers
Bosch dishwasher touch paint
Check with your small LOCAL specialty appliance store, (NOT big box store), preferably a bosch authorized dealer, give them your serial number and other info, they should be able to order it for you if they don't carry what you need in store.
May 27, 2013 | Dishwashers
Bosch Dishwasher Model SHU5316UC-06 -- what does error code 2H mean?
2H is not exactly an "error code", but it does indicate a problem. It means that the machine exceded its wash time by more than 2 hours. This is usualy caused by a failure of the heater, most often caused by a failure of the controll. Remove the control from the door, remove the plastic housing from the control, and check for a bad solder joint on the heater relay.
If you find a bad solder joint, REPLACE the controll.
Or call a qualified service person.
NOTE: The SHU53A dish washer with serial numbers from FD8205 to FD8507 are included in a factory recall. If your dishwasher is one of these contact BSH @ 1-800-586-9226 24/7.
Mar 28, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dish washer not washing
are any lights blinking is there an error code on the disp whats the model #
Jul 01, 2009 | Dishwashers
My Bosch Dishwasher cycle runs for 2 plus hours!
If this unit is running for a long time it is because it is still try to heat the water temp up it is eather the control board or the heater.
Mar 28, 2009 | Bosch Dishwashers
Lost manual washer wfmc530 cuc Bosch
Go to managemyhome.com and register. This is a FREE service. Once registered, go to the "Home Manager" heading and select "Owner's Manuals" from the drop down menu. Type in your Brand name and the model number you provided and your Owner's Manual is available in a down loadable .pdf format. I hope this helps you.
Mar 28, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Need Bosch stand mixer's model number to buy replacement parts
Just some added information. The number you have may be a part number. I ahve the exact same number on my Bosch Universal Mixer. What i'm looking for is a new casing, mine is broken.
Mar 15, 2008 | Bosch Kitchen Ranges
Bosch 24 in. SHU43 Built-in Dishwasher Logo
99 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
