Question about Performance Teknique ICBM-892 Car Audio Amplifier
I have a 1200 watt Performance Teknique ICBM-892 Car Amplifier which powers 2 10 inch polk audio db104 how do i tune my amp to get max power from those subs
    New Friend:
Wire the speakers to 2 ohms
Posted on Nov 25, 2013
2 Suggested Answers
  • 631 Answers
SOURCE: performance teknique icbm 892 1200 watt amp
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Posted on Sep 22, 2008
I Hooked up a Performance Teknique 1200 watt 2 channel amp to my 2 12" comp kickers. and before doing all this i took out the fuse. from my car battery. after everything was hooked up i put the fuse back...
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Jan 13, 2010 | Performance Teknique ICBM-892 Car Audio...
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
Icbm-892 amp performance teknique on protection mode
see what the volts and uf are and u can desolder the old one with some solder wick and find a replacement out of some old junk electronics that is the cheapest way I have done this many times and the used one does not have to be black
May 07, 2009 | Performance Teknique ICBM-892 Car Audio...
I got a performance teknique power amp its 1700 rms at 1 ohm i need 1500 rms at a load of .67 will be ok
No, with 1700watts at 1 ohm the max current is 41 amperes, with 1500 at 0.67 the currents is almost 48 ampreres, you will be overdriving the amp at signal peaks.
Apr 08, 2009 | Performance Teknique ICBM-782 Car Audio...
Performance teknique icbm 892 1200 watt amp
Sep 21, 2008 | Performance Teknique ICBM-892 Car Audio...
Audio system set up
Well one problem is you might need a smaller amp depending on how many speakers you have, 1200 watts is way overpowering for 300watt max speakers and could possibly blow them and even catch them on fire!!!! But everything else is compatable because all of your epuipment is of a newer products but if you dont have 4 guage wires or anything else make sure you get them heres a list: 4 gauge wires for power and ground, REM wire "blue is the normal color" RCA jacks, A compacitor, fuse for battery to amp to keep system from blowing up, 8 gauge speaker wire or even 12 guage to hook up from the amp to the speakers, That should be the common things you need to have a good thumpin system!!!!
Sep 12, 2008 | Performance Teknique ICBM-892 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Performance Teknique ICBM-892 Car Audio Amplifier Logo
195 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
