Pan drive is write proction - Computers & Internet
  • 570 Answers
From Start menu, point to Run, type in: regedit
If you are using Vista or Windows 7, just type in regedit in the search box when you click on the Start menu.
Navigate to the key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
Find a sub key inside that is named "StorageDevicePolicies". If it does not exist there then we need to make it. Right click on "Control" key -> New -> Key. Name it "StorageDevicePolicies" without quotes.
Now right click on this newly created key and then click New -> DWORD value and name it as "WriteProtect".
5
Double click this key to modify and give it a value 0. The value 1 in here means to enable it, while the value 0 is the opposite to disable it.
6
Click OK button to save and exit Registry Editor.
Thanks.
Have a great day.
Posted on Oct 11, 2010
Removing write proction
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope it helps
Jun 10, 2012 | Electronics - Others
Proction light stays on
If it stays on even when the speaker are not connected to it then the amp is fried but f it goes off when the amp is hooked up with no speakers then check the Ohm load on the amp and wire the speakers to match that but don't go below the ohm load on the amp...this site will help.... http://www.crutchfield.com/S-ApB0sVuYqNs/learn/learningcenter/car/subwoofers_wiring.html
Aug 13, 2011 | Performance Teknique ICBM-774 Car Audio...
I have a sonny rear proction tv its very foggy the piture
Three things you need to do:
1) Take the back cover off and clean the:
a) Mirror with glass cleaner
b) The dust that collected on top of the CRT lenses
2) With tv unplugged, use a flashlight and look down the lense of the blue, green CRTs. There is fluid in there. If the fluid is not clear, then it needs to be replaced and the tv re-aligned. Not recommended for anyone without experience.
Cloudy fluid is typically indicated by a foggy picture. THis is assuming you have a standard 3 CRT rear projection TV.
Mar 08, 2011 | Sony Televison & Video
My sandisk microsd card has write proction on it how do i get it off?
there a small switch on the side of sandisk (White) change position. and try again
Jan 02, 2010 | SanDisk 2GB microSD Memory Card
Proction stays on
CHECK ALL UR WIRE AND FUSES .. MIGHT BLOW ... OR UR REMOTE WIRE FUSE ... SEE U ..
Jun 20, 2009 | AudioBahn A4125HCQ Car Audio Amplifier
50" Akai rear proction tv
you may have a short in your poser supply best thing to do is take it to a shop and have them repair it
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Write protect Error
Hi ............
last month i purchased 4 GB pen drive. now it working in Write protected mode and accepting 1 GB data transfer. please suggest me solution for this problem to my mail ID
skumar529@gmail.com
Sep 04, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Windows intall
plug in your your pan drive in usb then after take windows xp bootable cd put in your cd drive & boot from the cd rom drive
then after set will be start then after setup select partion option come during the installlation so select ther your pan dive drive
then after setup will format your pan drive then after finesh the full installation of the xp then after redey ur xp in pandrive
try & enjoy make shoure ur pan drive capsity mustbe higher then 2gb
Mar 24, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
