Question about Panasonic DP-8016P Copier
Tray no 1 add paper - Panasonic DP-8016P Copier
  • Obertelli
    Obertelli Oct 11, 2010
    The message means exactly what it says: add paper to tray number one as it's empty.
    Problem Solver:
  • 13 Answers
Open and close all doors and still it there check senser and check inside machine by removing paper tray
Posted on Oct 11, 2010
I replaced the #1 drawer for a RICOH MPC2051 after install it keeps saying on the screen add paper to tray 1 and the paper tray is full? can you help. James
Take of the lower back cover and check the lift mechanism to see if it is lifting the paper. Make sure there no paper debris stuck behind the cassette.
Apr 03, 2017 | Ricoh Office Equipment & Supplies
MY BROTHER MFC 9440CN KEEPS SAYING NO PAPER RELOAD PAPER IN MP TRAY
not sure if your on copy mode or print mode ..close the MP tray door....turn off then on go to general setup select tray 1. not sure if your on copu mode or print the machine wants you to add paper to the tray that needs it. if you add paper dowes it still say"add paper" .if this is the case then the tray sensor is 1)broke2) pushed out of the way folded3) tray feed roller are not installed correctly no allowing sensor ..make sure your printer settings(properties) are set the that tray.
Oct 16, 2014 | Brother MFC-9440CN Laser Printer
Add paper/add paper try 1/try 2
Is the error stating to add paper? If so, go ahead and add paper to the trays necessary.
Jul 23, 2014 | Panasonic DP-8020E Multifunction...
In printer it showing Tray 1 ADD PAPER but [paper is added to the tray still it is showing that error so what to do ? give me the solution.
1.May be because of paper sensor.try to change it
2.may be you have given wrong paper size.u might have give wrong paper size.for ex for A4 paper u might have given some other size like a3. check this it will work for u
Jan 31, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
Tray 1 add paper messege on display .... no working paper also in tray but messege displyed.
Sensor for the first paper draw that detects paper has dust or dirt on it or has failedand requires replacement clean with can air or sensor acutator is missing or broken
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2010 | Panasonic DP-8016P Copier
Panasonic Workio 1810 - Tray 1 Add Paper Message
First why is the tray set for size A4 Paper. That is metric size paper for oversea locations. Should be set for 81/2"x11, or 11"x81/2.. is there any paper stuck behind the 1st tray? are the guides that hold the paper in place in the draw snug up aganist the paper in the draw. is the bottom sheet of paper in the stack/rem of paper benton the edge. All sheets of paper in the draw must be flat.
Jul 20, 2009 | Panasonic Office Equipment & Supplies
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
E240 LEXMARK WON'T PULL PAPER FROM TRAY 2
Try pulling out the tray and looking for the feed rollers that pull the paper up into the printer. The 2 rollers should have rubber "shoes" on them (they look like thick black rubber bands). Remove these roller "shoes", turn them inside-out, and put them back on the rollers. This worked for me, maybe it will work for you too.
Mar 31, 2009 | Lexmark E240n Laser Printer
How do we add an additional paper tray to the existing printer?
from the printer menu, go into the paper menu, change the "default source" to tray 2.
Also, on each computer that you have the driver loaded on, you can right click on the printer icon, go to properties, and select your default printing options.
Oct 27, 2008 | Dell 5100cn Laser Printer
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
Panasonic DP-8016P Copier Logo
285 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
