Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv won't turn on and there's a light on the front flashing that says standby/timer
  • 998 Answers
Try to look for the leaky capacitors if same problem occurs check your h-out.
Posted on Oct 11, 2010
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Televison & Video
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
