Question about GE WSM2780W Stacked Washer / Dryer
The center of the wash timer of the washing machine needs to be replaced. I was given a part # but when I enter the number to try and order, the number is not recognized. The model is: GE wsm 2782 wbwww Part # is: 131758600B This is a stackable w/d unit
SOURCE: Water from GE Washing Machine is coming from under my washer onto the floor
I would be happy to help you through this. The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with meatal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement. I just paid $59.99 for mine. It took me less than 30 minutes total to replace. Feel free to ask more questions. I love this kinda stuff. Good luck and let me know how it goes.
Tim....Denver, CO slamarama@comcast.net
Posted on Dec 13, 2008
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
SOURCE: Door seal on GE Adora Washing Machine
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
Posted on Mar 31, 2009
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
  • 3 Answers
SOURCE: Need to find an Eaton timer for a GE washing
What is the GE part number it ? What is exactly the problem with the timer? Is i the AC timer motor or is it the contacts? You may be able to disassemble the timer & repair it.
Ebay is also a source for older parts.
Posted on Jun 19, 2009
Washing machine wont turn on
see this instructions and fix it. God bless you
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Enter your model number to see parts for your washing machine.
Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Jul 21, 2013 | Washing Machines
Isnt gettin power but cord work outlet works
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you3958e768-3a49-432b-8096-35c2e90be05f.gifbf55c0bf-2b61-4cdd-8831-a6dc82140f68.jpg
May 23, 2013 | Maytag MAV7600 Top Load Washer
Maytag washer mav7600aww doesnt get power
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you938a0a02-c262-417d-a982-3a081cef735f.jpg2b39c595-65d9-457a-8ed4-d3bb6d2facd8.giff6783cbc-852f-47b4-98d7-bd94a664080e.gif
May 23, 2013 | Washing Machines
Simpson swt802sa
he most common parts or causes, ordered by the likelihood of fixing the symptom.
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you11c63312-8cb1-4484-928d-4b5c239b0f35.gif243403b0-440d-4f8b-b217-fdfd20c409ef.jpegc0210118-4dbd-4ea4-980b-16577c9769fb.gif
Whirlpool washer will occasionally be filling with water and pumping water out, problem will last until i turn timer knob to next action, after turning timer to "sweet spot" washing machine will...
These timers are normally sealed units (crimped and pressed sheet metal) and replaced as a unit.
If you could open one up, you'd find
that the contacts causing the intermittent problem are burnt from arcing. All washing machine timers
will eventually get this problem with enough use. As an electrician, you'll recognize that all switches
(washing machine timers are a series of switches oriented around a slow (timer) motor) are rated
for a given number of make/break cycles. Washing machine timer contacts are no different.
If you could actually "shine up" the offending pair of burnt contacts, another pair would soon
show the same symptoms, since all the contacts in your timer have endured the same number of
make/break cycles.
Feb 21, 2011 | Washing Machines
Cannot set Control dial for wash cycle. Knob will not move indicator dial. Rotating without engaging indicator. Thanks
Pull the center knob strait off. I suspect the center shaft of the knob is broken. If it is order a new knob but before replacing it make sure the shaft on the timer does not have a metal sleeve from the knob remaining on the timer shaft. Temporarily you can try to use needle nose pliers to turn the shaft to see if the washer works.
Aug 21, 2010 | Washing Machines
Does not advance wash cycle if i advance it by hand it seems to finish as long as I move the dial forward otherwise it sits on initail cycle
Hi, Sounds like the timer needs replaced. If you will get me a model #, I can look this up for you and get you a part #.
Vic
Jul 02, 2009 | Washing Machines
Electrolux EW 1005f washing machine trouble.
http://jaipur.justdial.com/washing-machine-part-electrolux_Jaipur.html
click this link for eltrolux parts in jaipur
http://delhi.justdial.com/washing-machine-part-electrolux_Delhi.html
click this link for parts in delhi
http://machines.exportersindia.com/cleaning-equipment/washing-machine-parts.htm
click for all other leading part suppliers
http://govindenterprises.tradeindia.com/
click the link
GOVIND ENTERPRISES RZA/337, Nihal Vihar, Near Guru Harkrishna Nagar, Delhi - 110041, India
Phone:91-11-25943604
floating-close.gifContact Now
floating-sendmail.gifSend E-mail floating-callmefree.gif Call Me Free
Key Personnel Mr. Bhupender Singh (Proprietor)
Mobile:+919212646376
Mar 26, 2009 | Electrolux Washing Machines
Kenmore washer 110.92292100..Washer Timer Control Knob is broken, just spins around..don't know how to get it off to replace it. Need a replacement part. Called a repair man, he wants $75.00 just to come...
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is searspartsdirect.com. YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
GE WSM2780W Stacked Washer / Dryer Logo
116 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
