Question about Toshiba Satellite A105-S4334 Notebook
My cd/dvd rom drive does not appear. It's as if it does not exist when you try to access it through My Computer or any other way.
  • barnvc Oct 11, 2010
    I am not able to see it under device manager. The computer is not recognizing that my drive ever existed on the computer
    President:
  • 2,291 Answers
Go to device manager and check there for troubleshoot , clean up ur registry key for driver use reginout cleaner may fix it
Posted on Oct 11, 2010
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD optical device
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
Lost access to my DVD/CD ROM after updating Microsoft files. Running Vista on a Dell Inspiron 1721 laptop. Tried to delete low filter in Regedit but that filter does not exist.
you can try to searh for upperfilters in the registry and delete it. if it did not exist, kindly try to perform system restore on your computer as it is a way as well to restore the registry settings. ( restore your computer to an earlier time as the DVD/CD is still working )
May 10, 2011 | Computers & Internet
Recently formated my laptop via a usb flash drive since my cd/dvd rom doesnt seem to work,and unfortunately the cd/dvd rom still doesnt work,doesnt appear under my computer,i ve no way of accessing data on...
Hello
Head of to the Acer website.Put in your model and serial # of your laptop. Find and download the cd or dvd drivers and install them on your laptop.
Also have you done the windows updates? Usually this will solve the problem.
Mar 25, 2011 | Acer Computers & Internet
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
CD-ROM drive doesn't load/play CDs or DVDs on laptop computer.
Check device manager for marks, red cross's etc...on the devices list, look in here,
Start, control panel , system/maintainance,
device manager, disk drive in here, right click, scan for hardware changes, update diver,
or double click it, driver tab, try roll back, or update & search, internet needed,
if no light's or no activity after this and all connections are good, ESD kit, needed to test that, then it's drive failure.
Check the media on different Computer, if it functions
You have just confirmed it.
Regards.
RPF.
Apr 15, 2009 | Computers & Internet
142307-001 cd rom drive need to buy
Take the existing CD-ROM to any computer-store, and, for $30, you can buy a compatible CD/DVD reader/writer.
Jan 03, 2009 | Compaq (142307-001) Internal 24x CD-ROM...
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
Drive doesn't play CD-ROM but plays DVD games...
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Dec 26, 2006 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Toshiba Satellite A105-S4334 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
