Please tell me how to install the rinse aid injector (part #WD12X0398) into the inside panel of the dishwasher
SOURCE: ge potscrubber 640 dishwasher
You probably have a restricted water inlet valve. It is not allowing the proper rate of flow for the allotted time, therefore not giving enough water to create the proper velocity to reach the top rack.
SOURCE: Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
SOURCE: Dishwasher Timer won't advance
my timer has stopped functioning altogether. it was first an intermittent problem, but is now 100%.
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
SOURCE: ge potscrubber dishwasher will not
Had the same problem with my dishwasher. Took it appart thinking that something was plugging the drain but there wasn't anything. Turns out the cylinoid that has the hook coming out of it to control the flap for the ejection of the water is broken. When looking at your pump, you should see a small flapper valve on the exterior of the pump hooked up to a small cylinoid that when accivated flips a flap in the pump to eject the water out of it instead of letting it circulate in the unit. This is an easy part to replace, but for me, hard to find since my potscrubber is so old. Hopefully your units are newer and you can find this part at your local appliance shop.
