Question about HP COLOR LASERJET CP 3505 N PRINTER
Hp cp 3505 show 59.co error - HP COLOR LASERJET CP 3505 N PRINTER
  • 987 Answers
SOURCE: HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
3. Replace the D.C. controller board.
Posted on May 15, 2009
SOURCE: error co 59
i have printer 5550 error code 59.0 coming so i need hp sevice help
Posted on Jun 14, 2009
  • 81 Answers
SOURCE: 59.c0 error in hp clj 3505 printer
Looks to be a motor error that drives the cyan toner cartridge. try swopping the cyan toner cartridge first because they can go stiff and hard to turn when they get older, this will then slow the motor down and cause a service error
Posted on Oct 14, 2009
  • 81 Answers
SOURCE: getting a 59.c0 error on hp clj 3505
Is the transfer unit installed correctly?Check and refit the transfer unit.
Posted on Oct 15, 2009
  • 17 Answers
SOURCE: HP COLOR LASERJET CP 3505 N PRINTER: Magenta toner is light in color.tryed changing the...
Known problem with this machine the fan is located next to the magenta laser scanner at the base of the machine. this fan blows dust on to the scanner lenses and makes the prints light. Needs to be taken apart and cleaned. take it to a local service center if they know what they are doing should be less then an hour.
Posted on May 20, 2010
My printer is showing error 59.0F Hp laserjet cp 2025
see some articles below for similar errors.
It does not appear to be user fixable error unless it is that debris to be cleaned. Printer HP Laser Jet CP4525 59 F0 Printer Error
Apr 28, 2016 | Office Equipment & Supplies
59 co error
An error occurred with the developing
separation-drive assembly.
1. Check that the following connectors on
the driver PCA are seated correctly:
J403, J405, J213.
2. Check that connector J1020 on the DC
controller is seated correctly.
3. Check that connector J5008 on the
fuser motor is seated correctly.
4. Replace the developing separationdrive assembly.
5. Replace the memory-controller PCA.
6. Replace the fuser.
reseat fuser - something may be binding causing error
Oct 08, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
Hp error 51.21
Here's what your error means : A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Dec 24, 2012 | HP COLOR LASERJET CP 3505 N PRINTER
Error 59.CO
1. If the main drive assembly has been
removed for service repair, verify that
the main drive assembly is calibrated
correctly. Click Here for Fuser
2. Check that the following connectors
on the driver PCA are seated
correctly: J403, J405, J213.
3. Check that connector J1020 on the
DC controller is seated correctly.
4. Check that connector J5008 on the
5. Replace the developing separationdrive
assembly.
6. If the developing separation drive
assembly has been replaced and the
error still occurs, calibrate the
developing separation drive assembly.
7. Replace the fuser assy...
Sep 20, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
RFU upgrade for HP CP 3505
u have upgrade the firmware for this printer.
the following link has firmware file download for thi printer. choose the operating system & download the firmware.
before you start the process read the readme.txt file caefully .this file contain the information about the firmwae upgrade.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3290547&taskId=135&prodTypeId=18972&prodSeriesId=3290546&lang=en&cc=us
Aug 10, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
59.C0 Error on hp color laser jet cp3505 printer.
The connectors in the primary transfer roller engaging motor drive signal line are not connected properly. Reseat the motor connector J5005 and the DC controller PCB connector J1014.
2. Faulty primary transfer roller engaging motor. Replace the motor.
3. Faulty DC controller PCB. Replace the DC controller PCB.
Hope this helps. If it does, pleaseaccept and rate the solution! Contact me with any more questions you may have.Thanks for using FixYa!
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
I can not add 3505 on my laptop
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Nov 08, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Close top cover error hp 3505n
just check your user manual, or simply download it from hp.com
Apr 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Color Laserjet 3505 13.20 service error
There is a set of sensor flags on the bottom of the paper input unit (paper feed assembly). You may be able to see them if you take out tray 2, remove the toner cartridges, and turn the printer on its back. One side of the rod can get stuck, it will make it look curved, it should be straight. "un-stick" the stuck side (typically the left side) so the flags can move freely.
Apr 03, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
HP COLOR LASERJET CP 3505 N PRINTER Logo
232 people viewed this question
Seeker5211
Seeker5211
