Question about Samsung Digimax D53 Digital Camera
Camera not turning on
Whenever i try to use my camera it beeps thee times and the grenn light comes on, but won't turn on, what do i do
  • 2 more comments
  • bluerio Jun 16, 2008
    Similar problem. I discovered it seemed to relate to the memory card. If I took the card out, the camera turned on and the Samsumg logo appeared - put the card back in and got the start-up sound, but screen blank white and lens came out only partially.
  • crearr Jul 26, 2008
    I get the same, three beeps and will not come totaly on. The cover opens, but the lenz will not extend.
  • xxx_sevin_xx Jul 26, 2008
    when i push the power button the screen comes on for a second and says low battery and shuts off, but it has new batteries in it.
  • on_que Jul 29, 2008
    i've got the exact same problem as crearr
Mine does not beep but makes a clicking sound and just wont turn on even when connected to a pc....
Posted on Nov 04, 2008
Our camera had the same problem where it beeped three times, green light and screen on, then turned off. I think the problem is with the lens not being able to extend, possibly due to dirt. I held the camera face down and turned the camera on while banging the corner of the camera against my hand. I think using gravity and the banging dislodged the lens, allowing it to open.
Very dissappointing that the Samsung website doesn't have any help, much less the fact that it didn't even list this camera.
Posted on Jul 26, 2008
My camera just wont turn on period and just used it like half an hour ago
Posted on Jul 06, 2008
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
When turned on camera beeps 3 times & the zoom
Does it take standard disposable batteries or a rechargeable pack?
If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries.
If the second type, recharge the pack.
If problem continues check Troubleshooting section of manual or online at Samsung's website.
Sep 20, 2011 | Samsung Digimax S600 / Kenox S600 / Cyber...
My ps3 slim wont turn on. The green light comes on but nothing shows up on my tv.
have you checked the connection from your tv to the ps3? it might be damaged and you might need to buy a new output cable
Jul 27, 2011 | Sony Playstation 3 (PS3) Console
Whenever I press the power button on my camera, the green light turns on, it beeps and never turns on. I don't know what to do to stop this problem from occurring.
HMMMM dis usually comes when there is a falt i your camera . da beep meanss there is an error usually .i think your camera lens is stuck.... and it wont even budge if there is da slightest friction , take it to a repair shop or service personnel
May 30, 2011 | Cameras
Traction systen warning message.The right turn signal also blinks rapidly if turned on,both dashboard grenn turn signal lights also intermittently come together venture 2001.
traction system warning message.The right turn signal also blinks rapidly if turned on,both dashboard turn signal lights also on come together venture 2001.This happens when it is cold raining and the automatic head lights are on and the brake pedal is depressed.
Oct 09, 2009 | 2001 Chevrolet Venture
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
NV30 froze
Samsung NV30 turns on then beeps then turns off
Oct 29, 2008 | Samsung NV30 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax D53 Digital Camera Logo
212 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
