Question about Sony Ericsson K800i Cellular Phone
How to flash of mobile o/s & re install ? - Sony Ericsson K800i Cellular Phone
How do I update.my.moto g phone to.android 4.4 KitKat?
You will have to wait for Motorola to release 4.4 KitKat.
Or you can root your phone ut pick a root that constantly updates like cyanogenmod.
Nov 06, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
I have forgotten the lock code of my nokia phone 5800 & also my phone restarts automatically one or twice daily. I did hard reset but same problem persisting.
Flashing is the onlyway so contact mobile tech or just follow the steps if you want to do it by yourself.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5800 365 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.http://adf.ly/2WHa2 this the link for blur nokia
For your file, there are different types so, choose the right file after you get the Blue nokia.
Sep 18, 2011 | Nokia 5800 XpressMusic Smartphone
During flashing the software the ovi stopped responding then said failed now e71 wont even start to boot any ideas on how to reinstall symbian?
There is software installation failure to reinstall your mobile software you should use the mobile flasher e.g JAF software Flashing Tool, or UFS Software Flashing tool both are having a bunch of all Nokia mobile cables & software's you must select the perfect cable & software of your mobile then you can Flash your mobile. And main important thing If you are a Mobile Technician then only you can use thous tools to flash your mobile using proper method. If you are not a mobile technician then please don't try to do such things otherwise your mobile may get dead forever.
If you are not a mobile technician then please Visit your nearest Nokia Service center or you can Visit any Malty brand Mobile repair center they will use the proper method to flash your mobile.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jul 06, 2011 | Nokia E71 Smartphone
I HAVE FORGOTTON THE CODE OF WALLET, HOW CAN I RESET IT,PLEASE HELP ME
Hi
Note : Please take the backup in your mobile (Contact, Gallery, and remove the Memory Card0
Easy to format yor wallet Nokia 7610, download the nemesis 1.4 software and Install in your PC, open nemesis software and now connect your mobile and your mobile screen is show 3 option now select PC Suite option,
The Nemesis also detect your mobile. Now click the device info.
Then click the flash, Now select the mode option (Red & Green)
first u select you see down option after flash and click the Reset -Full Factory, and upload, take earth 2 min your mobile will restore and restart automatically now put the date and time in your mobile and enjoy that
May 11, 2011 | Nokia 7610
What is sony ericson w930i flash code
Hello and Welcome to FixYa!
In order to Flash the mobile to Factory Settings, you wouldn't only need a flash code. You need to re-install/upgrade the firmware of your mobile. If you need to flash the mobile in order to retrieve the Phone lock code, you can have it done through the following link to the Tips & tricks section, that might be helpful to you. Click Here
Hope this helps, Concerned.
May 08, 2011 | Dryers
I forget restore security code and my mobile is nokia 3120 classic
1)download nokia flash tools http://www.mediafire.com/?mudeyqowwc5r868 .install nokia pc suit7.1.extract the folder you downloaded. then frst install jaf setup and then copy nok4model.ini and ogm pkey to the jaf installation folder.ope ogm and hit the go button.select bb5.swicth off the mobile connect it to the pc.select read pm click on sevice button.slightly push the power on of mobile.pm reading will start open pm file go to 308 block and in the 5th line you will see your security cod
or try it:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Mar 27, 2011 | Nokia 3120 Cellular Phone
I need to install flash player 10.1
I want to download adobe flash to my mobile
Feb 03, 2011 | Computers & Internet
Downloading/installing adobe flash player on a nokia 6300
i want to download adobe flash player on my computer & then install it on my nokia 6300 mobile phone.
Jul 29, 2009 | Nokia 6300 Cellular Phone
I have to hack flash player from other mobiles.Please tell me the process how to hack flash player from other mobiles.
Flash player is an application and it can be installed on any mobile, if it supports flash content to be played in it.You cannot copy the flash player from another mobile which is already installed in it. But you can install it by downloading it from web.
Apr 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
64 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
