Question about Pentax Optio M20 Digital Camera
Pentax Optio M20
My Pentax Optio M20 lens retracts after being turned on, and the camera won't stay on.  Grit in the lens mechanism?
  • mike_garcia_ Jan 17, 2009
    camera turns on lense retracts then turns off gritty sound when retracting
  • 797 Answers
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
Posted on Jul 19, 2008
SOURCE:
Lens won't retract
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
Sep 06, 2009 | Pentax Optio M20 7MP Digital Camera with...
Lens won't retract
some cameras you can just push the lens in.
Jun 29, 2009 | Pentax Optio M20 7MP Digital Camera with...
Turning it off
If you are talking about turning off the camera, it should shut down by touching the same button which you turned it on with.
You can remove the battery and see if the camera will then reset itself and retract the lens.
If the lens will not retract, you have a lens problem.
Jun 27, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Jan 01, 2008 | Pentax Optio S Digital Camera
Vista software needed for optio m20 camera
i require the software for my pentax optio M20 i now have vista
Oct 19, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio M20 Digital Camera Logo
295 people viewed this question
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
