Why does my brand new amp go into protect mode everything is hooked up right
  • 998 Answers
Your speakers might be the problem or check the impedance of your amp.
Posted on Oct 11, 2010
What does my protection light come on after hooking everything up
There is something shorting out the amp. What you will need to do is disconect all wires and hook up one at a time. Connect ground, !2 volt and remote see if amp turns on ok. If it does try connecting each speaker seperately to see if either one sends the amp into protect mode. Then connect the rca. See what causes the amp to go into protect mode.
May 08, 2013 | Car Audio & Video
Well i was driving one day and my subs just whent out so i bought brand new wires and hooked everything up but the power protector light turns red whenever uu turn it up past volume 10 i really do not know...
It sounds like your amp is going into protection. I know it's frustrating, but this is actually a good thing. If you subs you have are drawing too much power and the amp can't keep up, it will shut off instead of melting the board. Usually, the protection mode only last a few seconds. The user normally turns the music down that the protection shuts off and the music plays again. I recommend looking at a larger amp for your subs, if you are going to play them that hard.
Aug 14, 2011 | Car Audio & Video
I have a brand new logic soundlab tx1002. it was hooked to a brand new radio and new speakers. When turned on, it is in protection mode. you get a popping sound from the speakers. we have checked all...
first disconnect one wire at a time, making sure the power is off. then connect power and check to see if your speakers are making the popping sound. when you do your speakers, make sure you disconnect both positive and negitive of each speaker at one time. when your amp goes out of protect mode you will have found your suspect wire. then trace to the issue. it could be as simple as crossed over possitive and negitive wires
cheers
Jan 11, 2011 | Logic Soundlab LSX2600 Car Audio Amplifier
As soon as I hook the amp up it goes into protection mode. But in about 10 seconds it flashes off protection mode but them goes right back into protection mode. And it keeps doing this as long as the amp...
If you disconnect your speakers and input and the problems remain it means you've blown your end-stage and the amp needs repair.
if the problem disappears when disconnecting the speakers you may want to check if the impedance of your speakers is within tolerance of the amp.
Dec 23, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Got a problem with my car amp.Everything was working fine until 2day.Amp goes in to protection mode.Jumps from power to protection indicator every i would say 3 seconds and each time it goes in to...
Ok check the remote wire running from the headunit to the amp should be giving v12 feed whiles headunit is on.
check or change grounding position.
take cover off the amp as the circuit may be over heating.
Sep 22, 2010 | Car Audio & Video
Protection mode on my amp
YEA CHECK THE OHMS ON THE SUB TO MAKE SURE THEY MATCH UP TO THE AMP JUS SOUNDS LIKE THE WIRING IS OUT OF PHASE.
Jun 15, 2009 | Pioneer GM-7200M Car Audio Amplifier
Trubleshooting
you might nee a new speaker sounds like your amp is going into protect mode your voice coil might be going out try it with a diffrent speaket
Mar 01, 2009 | Car Audio & Video
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
