Question about Avanti FF1101W Top Freezer Refrigerator
Amana ARS9167AS Freezer Problem
Purchased side by side in May 2001 and now having problem with freezer - temp changes from 40 to 20, back to 40 and down to 10 over two-day period. Rusty water leaking out onto the floor. Repairman says it's shot - restriction in the freon tube cannot be fixed. Paid $1,596 for Amana product and hard to believe it cannot be fixed at all! The frig side maintains temp. Any suggestion most appreciated!
3 Suggested Answers
  • 15 Answers
SOURCE: Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Posted on Dec 15, 2009
  • 1044 Answers
SOURCE: how do I tell if I have a bad compressor on my
1 The cooling is less and may be nothing 2 It makes noise when it starts. 3 Lot of vibrations when the fridge is running. 4 Getting heated up beyond a certain limit.
Posted on Jul 03, 2010
Freezer not cold and forming ice in side?
Replace the defrost thermostat located on the coils in the freezer. Here is the part to order.
Dec 03, 2012 | Amana ARS2464B Side by Side Refrigerator
I have an amana refrigerator w side by side with freezer at the bottom.what is the best temperatur settinfg is most economical for this type refrigerator?
if you have a fridge/freezer thermometer great.leave inside each one for at least 12 hours to get average temperatures if in use. Answer .. the optimum temp for the freezer is -18/20c.0f, for the freezer and +2/5c.34/36f for the fridge.
Mar 10, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer workss but fridge dont
Check for a frost buildup on the interior back wall of the freezer. If you find this, a problem exists in the defrost circuit (heater, terminator or control).
Also verify that the evaporator (freezer) fan is functioning.
A failed damper control can cause this condition as well.
Proper product temps are 0 to 10 in the freezer and 36 to 42 in the fresh food compartment.
Apr 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
Freezer is not making ice and the temp seems to be dropping.
You may have a defrost issue,Please check and see if it has an accumulation of ice build up in the back and post back.
Jan 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
FREEZER WORKS BUT FRIDGE IS 50-55 DRGREES
if all that is ok then you need to check the heater and bi-metal / if it starts frosting up you loose air into the refrig side and the freezer will start going down too / frig side gets tem from freezer ,,,,, i bet you have a bad defrost heater / larry
Nov 29, 2008 | Amana ARSE664BS Side by Side Refrigerator
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
We have an Amana Side by side purchased in 2000. went on a 2month vacation, and turned the freezer temp down, and when we got home turned it back up, and now it won't keep the Ice Cream frooze, everything...
IS THERE A FROST BUILDUP ON THE BACK WALL OF THE
FREEZER INTERIOR? IF SO, AMANA IS MADE BY MAYTAG
AND THE ELECTRONIC BOARD THAT CONTROLS THE DEFROST IS MOST LIKELY SUSPECT. IT IS LOCATED IN THE UPPER RIGHT CORNER OF THE CONTROL PANEL IN THE REFRIGERATOR SECTION {INSIDE BACK RIGHT CORNER).
THE ENTIRE UPPER PANEL HAS TO BE REMOVED TO GAIN ACCESS. WHERE THE WIRES CONNECT, THERE ARE 2
TERMINALS MARKED TEST. SHORTING THESE TWO TERMINALS WILL ACTIVATE THE DEFROST MODE OF THE CONTROL. IF IT FAILS, REPLACE THE CONTROL.
Mar 27, 2008 | Refrigerators
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Avanti FF1101W Top Freezer Refrigerator Logo
108 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
