Question about Russell Hobbs 14339 Cordless Electric Kettle
Kettle does not stay switched on - Russell Hobbs 14339 Cordless Electric Kettle
Why won't our BOSCH TWK8633 stay switched on?
You don't say how old your kettle is, but if it is less than 1 month, I would go back to the retailer where you purchased. Make sure you have your guarantee or proof of purchase.... Otherwise, going by past experience, kettles that won't stay switched on usually need de-scaling. Even if you can't see any lime scale in the kettle, there are sediments in the water that will build up over time & that can cause the element to overheat. This makes the kettle switch off prematurely or not switch on at all. In the UK, regardless of where you live, you should de scale your kettle at least once a month. If this doesn't work, you should still go back to the retailer, but if it's found that the malfunction uis diue to lack of de-sclaing, this isn't usually covered by the warranty....good luck!
Aug 09, 2014 | Bosch Styline Collection Kettle Twk8633gb,...
Dualit kettle on switch wont stay on
The switch is worn out. If you feel confident about taking the kettle apart and reassembling it, you can buy a new switch at the link below. Otherwise, take it to a shop to have it repaired.
http://www.spares2go.co.uk/browse-DUALIT-72001-ON/OFF_SWITCH_-_RED-m125-p159253-s161139.htm
Jan 18, 2014 | Dualit Axis Cordless 1.7 litres Cordless...
My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Feb 18, 2012 | Chef's Choice 677 Cordless Electric Kettle
I have an Edinburgh (I think) kettle which I have been very happy with, but now the switch will not stay down, occasionally I make connection. What can be done?
The switch is operated on what is called a thermocouple - the most lightly problem is lime scale. Get some limescale remover from your local hardware. or you can use spirit vinegar and boil the kettle a couple of times. Give it a really good clean afterward or your coffee will taste awful! Good luck.
Aug 11, 2010 | Russell Hobbs RHOK3123 Cordless Electric...
Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Sep 13, 2009 | Alessi MG32 Cordless Electric Kettle
On Off switch problem
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Jul 08, 2008 | Russell Hobbs RHOK3123 Cordless Electric...
Alessi Electric kettle
The switch is most likely defective and has to be changed. It is also possible that the heating element is pulling too much current and also has to be changed.
An appliance service tech would have the tools to test the kettle and determine the exact fault.
Jerry G.
Apr 26, 2008 | Alessi Al384730-640 Cordless Electric...
Switches off before full boil
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
Russell Hobbs 14339 Cordless Electric Kettle Logo
43 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
