Question about HP Photosmart 4180 All-in-One Printer
Trying to change colour cartridge but comes up with message " Remove and check colour cartridge"
Ok les cuento nuevamente tengo una impresora Hp photosmart C4180 all-in-one le instale el cartucho negro y el de color recargado o bien generico y me derramo por todas partes tinta incluyendo las tarjetas el problema que me esta dando es que no me enciede la pantalla ni mueve el carro donde van los cartuchos de tinta quesiera saber que puedo hacerle para resolver este problema ya que la desarme por completo la limpie todita y aun persiste el problema. me pueden ayudar por favor , Gracias
Mi correo es Dennisemilianofloresolivares@yahoo.com
Posted on Oct 13, 2010
Colour ink cartridge not recognized. Dell 305 Printer
Have you tried restarting your computer with the printer switched? This sometimes works. Other than this you can get a little device that resets the chip on the rear of the cartridge. This sometimes happens with refilled cartridges.
There are many stationers who stock this gadget.
Jan 16, 2010 | Dell V305w All-In-One R840635AU InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
FATAL ERROR
your printer is laser printer change toner cartridge right,
you may try
1) Open the front door and remove the toner cartridge.
2) you will see a small round hole near the colour toner cartridge
3) hold a screwdriver in that hole and the carousel will rotate freely. 4) Move the carousel round and remove each one of three cartridges at a time.
set back all cartridge close door.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
"REMOVE AND CHECK COLOUR CARTRIDGE" KEEPS COMING UP NO MATTER HOW
this would probably be a printer failure itself, the print head that reads the presence of the the cartridges is failing and you need to check if theres any sign of leakage or broken parts
Dec 22, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fixed new colour cartridges, and they are saying that the colour cartridges are empty and they are full
please check whether the printout is coming proper when you give a print.
if its coming proper the cartridge is proper.this message is shown because in the printer there is a sensor which detects where there is a ink in the cartridge or its empty.so if the printouts are coming properly the sensor is bit moved from its orignal position or the sensors are damaged and became faulty to detect the ink in the cartridges.
so you use the cartridges let it detect no ink print out will come till the end of the ink.
or if still the prints do not come try changing the cartriges .
Sep 24, 2008 | Televison & Video
INK CARTRIDGE PROBLEM Remove and check cartridge on the right Refer to documentation hp photosmart 2575 all in one
Take the cartridge out and rub the contacts with a piece of damp tissue paper and try again.
Check the contacts in the printer itself where the cartridge sits. If there is any damage or pin hole on the white ribbon with the gold contacts on it then the printer is unrepairable but it sounds like a cartridge problem. Try changing the cartridge as well
Jun 13, 2008 | Office Equipment & Supplies
Hp psc 1610 alignment error
replace the colour cartridge aLSO AS IT NEEDS some specific colour to start this allignment and to complete but the colour is not getting printed so this error.
remove the cartridges from the printer.unplug the printer for some time.then again ON it and insert the cartridges and try .
sometimes it helps.
Jun 02, 2008 | HP PSC 1610v All-in-One Printer
Magenta ink colour
I had the same problem. Try cleaning the print heads. They tend to clog. Remove the cartridges, then remove the print head. Tilted slightly, it comes out easily. Run very warm to hot water over the print heads until they all run clear. Use a turkey baster to apply strong pressure to each head until it runs clear. Blow off the excess water with mouth or blow dryer. Insert into the printer and proceed to print. If that doesn't solve it, you might have a bad cartridge, but there isn't much that can go wrong with the cartridge. I have an ip4200 and an MP830. They have the same print heads and same cartridges. I have cleaned each twice and they work like new.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP Photosmart 4180 All-in-One Printer Logo
245 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
