Bauer portable gas room heater fault diagnosis
Hi, problem is when depressing the "control" knob and sparking the center ceramic lights but even when holding down for +- 10 mmins and slowly releasing the gas control knob the fire dies, it has always worked in the past even if a bit temperamental ! Pls hrlp, Thanks
G
5 Suggested Answers
  • 234 Answers
SOURCE: Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Posted on Mar 13, 2009
SOURCE: Pilot lights but main burner won't
sometime if the heater has been sitting for days spiders get into the burner area or the area between the tank and the burner and make a web blocking the flow. I have taken a compressed air in a can like the ones you use for computers laptops and blow air up the shaft and around the burner wait 2 minutes then try again. Sometimes it takes 2 or 3 blowouts to work.
Posted on Aug 21, 2008
SOURCE: ProCom blueflame heater pilot light difficult to light
Holding the button down enables gas to go to the pilot. When it lights you will see the flame touching two rod like devices. The small one is the igniter. The second one is a thermocouple. A thermocouple is a bimetalic device (2 disimilar metals) that when heated produce a small curren, this current in turns keeps the valve open for the gas to flow when you let go of the button. This is a safety feature. If the flame goes out on the pilot the thermocouiple cools and closed the valve shutting off the gas so you don't go boom! It sounds like the thermocouiple is bad or missaligned. If it is missaligned it will take longer to get hot enough to hold the valve open. Another thought would be the flame is not shooting out far enough (not enough gas pressure, clogged oriface on pilot(previous writer, leak but you get the idea. In my manual it had a picture of how the flame should look hitting the thermocouple. Good luck. My problem is I assumed that the regulator on my construction heater was the correct size. Maybe not. I have not had any luck getting the pilot to light at all. I hope I have not damaged the internal regulator.
Posted on Jan 17, 2009
zonaluver
  • 7 Answers
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Posted on Mar 29, 2009
SOURCE: Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
Posted on May 31, 2009
Installed Dyna Glo BF30DTDG-1 NG Heater, pilot / gas knob won't turn-why?
Spay some wd40 on control knob some times they are still to move .
Dec 05, 2016 | Dyna-Glo Heating & Cooling
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Williams 5009662 pilot light went out, can't tell where to relight
you relight it ,,but it is better you are lyning down to see where to light it,,,but some have a red botton that you push to relight it ,,,like a bbq grill it makes a spark and when you turn the control knob on pilot to light it
Jan 14, 2011 | Williams (5009622) Ceramic Gas Wall...
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
How do I lite a wall room heater
First, turn off the gas valve for at least 5 min and ventilate the room. Most wall heaters are lit the same as a water heater. Find a red button to push or turn the gas valve knob to the pilot position. While pressing the red button or the gas valve knob, hold a match to light the pilot flame. After it lights continue holding the knob for one or two minutes. If the flame goes out when you release the knob the thermocouple is probably bad.
Oct 18, 2010 | Williams (5009622) Ceramic Gas Wall...
New Fire Sense table top Patio Heater will not light. tank
they will be air in the gas line , and the pilot injector being so small it will take ages for gas to come through , you need to purge the gas line undo a union or nut or pilot suppy to purge the line of air test joints after with soapy water .
Jul 08, 2010 | Williams 2509612 Ceramic Mid-Size Heater
How do I know where to light the pilot on my wall heater? I'm not exactly sure where the pilot is. I know where the button is and the pilot knob but do I need to turn the gas on and how far should I turn...
I can try and help. Get a working flash light. If you know where the gas valve is, good I will take you from there. On the gas valve you will find a 1/4" diameter aluminum tube and a 1/16" diameter copper wire both screwed into the valve. Follow the larger of the two tubes toward the heat chamber. The tube will enter inside the chamber and you may have to unscrew a cover to get to the pilot. The tube goes to the pilot assembly. If you have button that snaps when you push it in, that is the pilot starter. Look thru a small viewing port and snap the button. You should see a blue spark. This is where your pilot assembly is.If there is no spark, your sparker is broke. You will have to use a ling match or gas grill starter to light the pilot. OK so if you have good spark, turn the gas valve knob to Off. Now turn it to Pilot and depress the knob into the gas valve. It should go in about 1/2". As you hold the knob in, snap the sparker button a few times and continue to hold the knob in. Look in the little window for a flame. Continue to hold in the knob for about 30 seconds after the flame lights. Now let the knob out and check that the flame is still lit. If it is, turn the knob to the On position. You should be OK from there. If you had to use a match, prior to putting the knob to the on position, replace any screws or plates you had to remove to get to the pilot. Good luck!
Dec 03, 2009 | Williams 3003622 Ceramic Wall Mounted...
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
