Question about HP Pavilion dv1000 Notebook
Femal pin jack
Any solutions of how i can get to the femal pin jack to see if i need to resoider it. thanks
    Genius:
  • 3,587 Answers
You'll need to take the entire notebook apart to access the motherboard..
Posted on Jun 01, 2008
Jack female connector type
switchcraft
your standard 1/4 in mono female jack.
Mar 18, 2014 | Ibanez RGD Series - RGD321 Electric Guitar...
What type of audio connector is needed
You need to be more precise than that. Audio connectors come in various lengths, diameters, pin type, coaxial, RCA jacks, and many other formats.
Restate you question and mention what device (Computer, DVD Player, etc.) the audio connector is for. If its like your ear-phone with Left and Right channels, you want a Stereo Mini-Jack (male in, female out), if it is like an umbrella style, that's an RCA male out to an RCA female in.
Dec 16, 2013 | Audio Players & Recorders
Need a jack as it is at the end of furuno microphone DM-1996FZ1 THANK YOU
Jacks are Jacks... is it male female how many pins, is it a simple DIN plug, a plug with a lock ring? there are multiple dealers that sell mic plugs (jacks are the part that is mounted to the radio itself, that the mic PLUGS into), Google copper electronics to start...
Oct 14, 2013 | Furuno 000-139-033 Microphone DM-1996FZ1...
I have a HP Pavilion a1213w who's sound is now distorted .....I replaced my original monitor with a View Sonic VX2250wm-LED.....everything seem fine then I lost my sound (volume control) & had to...
Your problem is independent from the drivers. You have to take a closer look at the connections. The description for the audio makes me believe that the earth wire for the audio (the outer cable) is cut, either from the 3.5mm jack side (the earth point at this jack is the biggest ring) or from the RCA jacks side (the earth point is the outer metal surface of the jacks). Try using another cable or a headphone set direct connected at the computer. Sometimes the problem may come from the female 3.5mm jack at the audio card. I hope that this is not your case but anyway pull in and out a male jack into this female in order to clear a bit the female side.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 18, 2011 | HP Pavilion a1213w (ED898AA) PC Desktop
How to install philips portable speakers to my hp computer
use a multi-out jack....it will have two out jacks(female) and one pin(male) to be inserted into the audio out jack on the computer, connect your speakers pins(male) to those 2 out jacks....
look for this.....buy it on ebay look for "Audio Spliter"
guess this helps...pls let me know leave a feedback for this solution...
reg
Apr 27, 2010 | Philips SBP1100/37 Portable Speaker System...
Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Sony VAIO® VGN-N130G/B PC Notebook
Problem with LenevoY510 laptop in TV tuner adapter
From your description it appears that the R-Female connector is for the TV aerial (a coax cable that connects the tuner to the aerial). This is located on the LHS at the front corner next to the IEEE 1394 connector.
The external video output is the S-video connector and this is located on the RHS next to the DVD/CD drive.
These cables common and can be purchased at the TV/electronics shop.
May 02, 2009 | Lenovo IdeaPad Y510 Notebook
Broken Female audio plug
take a 1-1/2" safety pin, straighten it a bit, heat the tip, stick it inside the broken pin, let it cool then work it out w/the broken pin attached. I had the same problem & this worked.
Nov 05, 2008 | Onkyo Audio Players & Recorders
Re Slingbox
The sling box has no input of 8 pin DIN,i look for another one.
I found an adapter has a female input of 8 pin DIN and has the output of female RCA jack> the only thing you do is to buy a male RCA jack in order to connect your DVD player,;
click below to see the sample picture;
511359689.jpg Pixel Perfect P.I.E. PIO/P-RCA Adapter P-Bus MCD To Aux Input
If i have helped, please click fixya;feel free to ask question,
Good luck and thank you in advance;
Jul 19, 2008 | Audio Players & Recorders
Femal pin jack
here are list of disasembling laptops/notebook so get yr srew driver,alen key, then log onto these site for instructions on howto.
www.repair4laptop.com
http://www.madmastersmachines.com/HPnotebookrepair.html
hope this helps
thank u
May 31, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
