Question about Intel Motherboard
P35 Neo2 Motherboard Jumpers
I have an MSI P35 Neo 2-FR motherboard and I am building the same PC profiled in Maximum PC April 2008 about building your own PC. I am using the Intel Core2 Quad Q6600. At first boot a message came up asking about overclocking to 2.4Gig and to Y/N to accept Bios settings, I entered Y. from then on the computer turns itself off after staying on for only a minute. I removed the jumpers and I have no video and processor error LED's are coming up on the Motherboard. The motherboard came with overclock jumpers set to 200Mhz. I have another CPU coming but I am not sure if the jumpers are the reason for the problem, they were not mentioned at all in Maximum PC, any help would be greatly apprecitated!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
A quad Q6600 is manufactured @ .273 overclocked from the factory. at no time should this cpu ever be overclocked anymore unlessd you are using a watercooling system that keeps the cpu @ 69 degrees for stability. anything else will burn it out. lala linda
Posted on Jun 02, 2008
I was wondering if my pentium dual core E5700 would work in a msi p35 neo2??
It should work just fine - The Pentium E5700 is an LGA775 and so is the MSI P35 Neo2.
However, installing a processor into a motherboard is a bit more complicated than simply plugging it in, so I would consider having a professional install it for you.
Sep 16, 2011 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
I want a copy of 915g Neo2-FR manual
You can download manual on this page:
http://www.msi.com/product/mb/915G-Neo2-FR--V1-0B-.html#/?div=Manual
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 09, 2011 | MSI 915G Combo-FR Motherboard
MSI 865PE Neo2-V Motherboard does not boot to BIOS. It just powers up and the drive lights are on continuously. Is there a replacement MB that uses essentially the same BIOS and won't require re-formating...
This one is pretty much identical
http://cgi.ebay.com/MSI-865PE-Neo2-P-Motherboard-P4-socket-478-EMS-/180572214688?pt=Motherboards&hash=item2a0af155a0
This one is similar but you will need to reinstall a new audio driver
http://cgi.ebay.com/MSI-865PE-NEO-2-Motherboard-Processor-/200552149636?pt=Motherboards&hash=item2eb1d6f284
Dec 09, 2010 | MSI 865PE Neo2-V Motherboard
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
Hangs on testing base n extended memory
appears to be a RAM/Memory Problem.
Or Corrupt Bios.
Try swapping The Memory to different Slots, or try 1 stick in Individual Memory Slots. Also Ensure the Board Has the Correct Ram Installed i.e DDR/DDR 2 et,c.
Mike @ Compurepair.
Nov 06, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Msi P35 Platinum motherboard bios problem with the latest bios 1.10. I want to put an oldest version, the 1.9 but i don't find a solution...
Flash the new bios and replace with the old one. The same thing you do when you update the bios of your motherboard.
Oct 27, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Hello please help i wanted to update bios for motherboard MSI P35 NEO2 and i didnt made a backup on a flopy disk (atleast i think this is the problem). Now after the computer restarted i get the message: I...
It seems to me that if your BIOS are not damaged, you can still make the copy and proceed as per procedure. Thank you for your consideration and choice for our service! My name is Constantin (arzconst is my internal nickname under Fixya.com).
Jun 19, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Msi p35 neo2
take off all the stuff from the mobo except the processor, a stick of ram and the graphics card - will it get further now?
Jul 02, 2008 | Intel Motherboard
Problem with motherboard MSI P35 Neo2-FR
suggest not, if you really wan try, go ahead, but i suggest not.
Jun 05, 2008 | Intel Motherboard
Intel Motherboard Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
