Question about Bugaboo Cameleon Stroller
How do I disconnect cradle from base - Bugaboo Cameleon Stroller
    Guru:
  • 541 Answers
Push in the two large white square buttons, you need to push both in together towards the middle of the stroller and one side has an extra release button as well, then lift the whole seat or bassinet frame up off the base.
Posted on Oct 30, 2010
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
Phone saying no link to base
Each handset in a multi-handset phone system must be identified by the base unit. This is because most units have an intercom capability that can communicate between two handsets. If the battery of a handset dies completely or is disconnected and replaced, then base unit loses it contact with the handset. To re-establish the connectivity, you must seat the handset in the charging cradle of the base unit. Once it is identified it can be taken back to its remote location.
Mar 24, 2015 | Lands Phones
WHAT DOES THE READOUT =BASE= MEAN
Remote handsets must be synchronized with the base unit. The remote charging stand will not perform this function. If the handset goes dead or the battery disconnected and reconnected, you must return the handset to the base unit and cradle it so it can be identified and synchronized to the base unit.
Mar 06, 2015 | Lands Phones
Out of range/no power at base
Most multiphone sets need to have the phones hung up on the same base all the time. They are set up as set 1 and set 2 etc. Look in the screen, it should say which is 1 and 2. 1 is always the main base. Try unplugging the power cord for a few minutes. It sometimes takes that long for the equipment to reset itself.
Apr 16, 2014 | Vtech 9009111 Cordless Phone
Handsets don't work say searching on all of them only base works
Reset the handsets that are not connecting (follow instructions in manual or try disconnecting battery, holding # and * while reconnecting battery and then pressing the rightmost button directly below the display) then set them in the cradle on the base station until they are connected. If this doesn't work, please post the model.
Dec 12, 2012 | Lands Phones
Plantronics CT-12, the red light charge in use is always blinking
You need to disconnect for a few seconds and reconnect the battery on the remote. While the remote is sitting in the charging cradle, press the talk button to turn on the remote and then turn off. Disconnect the ac power from the base for five seconds and reconnect. This should subscribe the two pieces together.
Good luck from Headsets Direct!
May 03, 2011 | Plantronics CT 12 Cordless Phone (CT12)
When the Talk button is depressed on one of our two handsets the screen reads: "No link to base. Move closer to base and try again." The other handsets performs as it always has.
Hi Jim.
About the problem with the answer received, you should write to premium.support@fixya.com. They usually reply within next working day.
About the system, if you have not sent the system for repair yet, you should do a full system power reset. This is done performing the following, simply disconnecting the power adapter won't be enough:
  • Disconnect all power adapter cables from wallsockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units in the system is defective.
I wanted to remind that the feedback given to the expert does not afftect refund procedure, and do not affect your status. In some case I get negative feedback while trying to help dissatisfied
askers in troubles with Fixya service. That is not really nice and pleasant. :)
All the best.
Ginko.
Jan 10, 2011 | Panasonic GigaRange KX-TG5240M Cordless...
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
Base handset out of range
Try opening the phone battery compartment on the back of the phone, disconnecting the battery wire, then reconnecting the battery wire. Solved my "Out of Range" problem - phone came back on and worked properly.
Nov 05, 2007 | Uniden DCT758-4 Phone
Bugaboo Cameleon Stroller Logo
78 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
